Originally Posted by Zone 5
(Post 4750687)
Okay guys. What is a "secondary" trim switch? Cause my drives and tabs both work fine, up and down.
They may not go to anything at all if the guy previous guy was too lazy to pull old wiring out when re-doing stuff. They look like the standard plugs that go into trim/tilt pumps...the purple wires would connect to the limit switches (the hockey pucks on the outside edges of the gimbal assembly) so the pumps know when to stop.
If everything works on the boat then either leave them alone or yank them out and clean things up....you can test them to make sure they not hooked up to the switches. Just place the ground lead of a volt meter on any good ground, then the positive lead into either the green or the blue wires and start hitting trim/tilt switches up/down to see if there's any power going to them... |
Originally Posted by Wally
(Post 4750720)
| All times are GMT -5. The time now is 06:30 AM. |
