353 transom assembly >
Old 07-16-2022 | 08:00 PM
Default 353 transom assembly
Currently doing a top end refresh on my 525s. While the engines are out i want to replace the port side transom assembly. Starboard was done by previous owner. Question is are these hp assemblies fron the factory ? I know my indicators are mechanical but there is a sender on them for trim limit I believe. No luck finding a hp assembly with sender so far.
anger mgmt is offline
Old 07-17-2022 | 07:31 AM
The HP assembly uses a single 3 wire trim and limit sender. Merc says to use one with a analog gauge you need a digital to analog converter. I installed one a few years back and never did get it to work.
AllDodge is offline
Old 07-17-2022 | 10:04 AM
I had the same issue with the hp i put on my previous boat, even with the converter the gauge was never accurate. I managed to track down a hp with a sender for the Formula. Part Number was changed at some point, why I was having issues locating one.
