XR Drive issues on 382's? >
Old 09-25-2022 | 02:35 PM
Default XR Drive issues on 382's?
Hey guys, There are a lot of 382's with the 525's and XR drives. I've heard the 382's have had issues with the XR drives due to the weight of the 382's. I've been told the drives are a bit undersized. Any truth to this?
Thanks.
43Golden is offline
Old 09-25-2022 | 04:01 PM
No, they don’t care what make or the size of the boat is,
they have issues on anything over 499 hp
JaayTeee is offline
Old 09-25-2022 | 04:10 PM
Thanks.
382's are heavy, but Bravos can and will fail on any boat based on many other factors. Bravo XR's are used on much bigger and heavier boats than a 382's.
The drives have always been undersized from Merc, really has nothing to do with it being a 382. 525's should be easier on Bravos than the bigger supercharged motors. Not sure what Formula used for a 382, but many 353's came with 5 blade props vs 4 blades - the 5 blades are harder on the drives as they have less slip.
Besides, Merc doesn't offer a better alternative to a Bravo XR in its line until you go up to the #6's and similar. Bravos can be upgraded in the aftermarket, but no guarantees
snowrunner is offline
Old 09-25-2022 | 08:17 PM
Yes, you will eventually have issues, even it you do everything right.
kjm5125 is offline
Old 09-27-2022 | 01:11 PM
I always carried a spare drive in the truck. Change drive oil every engine oil change.helps.....abit
fossil fuel is offline
Old 09-28-2022 | 06:01 AM
Quinlan's Avatar
I had to carry my extra pair and Props w the Cig whenever we traveled anywhere- as 1 pair of drives was 1/36 and 1 pair was 1/50- over 750 Hp and lots of air
SCXs solved that problem.
Quinlan is offline
Old 09-28-2022 | 07:34 AM
bencini231's Avatar
It's a lot of money up front, but the SCX uppers with dual downshaft lowers will provide you with way more trouble free boating than the XR's.
bencini231 is offline
Old 09-29-2022 | 07:03 AM
Thanks everyone for your feedback. Much appreciated!
43Golden is offline
