factory logo crooked >
Old 11-01-2022 | 07:22 PM
Originally Posted by jtbooten
I agree with this. Never understood why people put “Chevy” or “Ford” across the front windshield of their trucks… I like a clean debadged look.
unless your in a cigarette…I have logos on my underwear. Hahaha jk
1MOSES1 is offline
Old 11-01-2022 | 07:37 PM
High quality stickers, you can use a heat gun on LOW or hair dryer. warm up the stickers and they should slide off easy.
if they are old or not coming off easily, use a sticker wheel.
Amazon Amazon
SabrToothSqrl is offline
Old 11-01-2022 | 08:21 PM
SB
I agree. Boot the Formula decal on the back.
Bye Bye.
SB is offline
Old 11-02-2022 | 04:36 AM
Originally Posted by BBYSTWY
I'd pull it and buff the sh!t out of the back and make the name a little bigger with similar font/color....just my opinion
Yes thats sounds good. I found an online company that has that correct font 'Bank gothic" that can make it pretty close to original. thanks for the advice.
j272 is offline
Old 11-02-2022 | 04:37 AM
https://www.amazon.com/SATC-Removal-...s%2C119&sr=8-5
sounds good, thanks
j272 is offline
Old 11-02-2022 | 08:15 AM
Active Streak: 30 Days
I would not use the sticker wheel. Never had any good results. Use a plastic scrapper and get the edges loose. Spray WD-40 under the sicker and start working at the edges with plastic scraper or fingernails. The WD will loosen the adhesive and help to remove it from the fiberglass also. It's slow, but it works.
Helmwurst is offline
Old 11-02-2022 | 12:43 PM
ok thanks for the advice
j272 is offline
Old 11-10-2022 | 02:05 AM
Veteran: Navy
I saw a guy at the marina use oven cleaner to remove the name of the back of his boat. Between the removal of the name and buffing the gel coat out, about 2 hours. Look like new.
AmiableDave is online now
Old 11-10-2022 | 08:23 AM
I have used "fishing line" (on cars) to slide under and cut/separate logos/spoilers that were attached with adhesive/3M double sided tape.
F14A water jet is offline
Old 11-10-2022 | 11:54 AM
Wally's Avatar
Were doomed!
be very careful when doing this. It works great for painted on graphics...not sure about stickers. We did this on a friends 28ss cigarette when it was getting a renovation.. He left it on too long and it discolored the gel. We were using easy-off oven cleaner
He didnt mind too much as they ended up painting the boat later.
-Wally
Wally is offline
