Fast tech 383
I'm looking at two fast tech 383 poker run edtion's both are 1999 fully loaded with gen sets. Any feed back thoughts on speed handling, cabin etc. Would be greatly appreciated.
Bought it for comfort - A/C, GenSet, hot water, TV/VCR, etc., etc., etc., and have done lots of cruising and overnighters with it, including a 10-day trip all the way around Chesapeake Bay. Other than a little short on headroom, the cabin is as comfortable as they get (UltraLeather - mmmmmmm). Mine has 600 Volvos and will run in the high 70's with a full load of fuel on a very hot and muggy day. 500 Mercs will probably be as fast or faster, especially if you have standoff boxes.
Handling/ride? - certified wave-smashers (No problem).
Are you looking at the ones at Trenton Marine?
Thanks guys for your thoughts. C_spray will she break 80 with a lite load of fuel? The two I'm looking at is in AZ and CA. The ones at TM are not poker run edtions. I like the faring and straight exhaust out the back with boxes.
Great wave crusher with an awsome cabin. Best thing about a formula beside the reliability is a cabin you can use in style and comfort. As long as you don't buy impulsiv you will never go wrong.
Russ
Russ
Isn't it true that the Poker Run Editions have no cabin? If so, I would think that they would be 4-5 mph's faster due to a much lighter weight.
Craig
ps. I think FullTilt marine had one for sale w/500's for 99,000
Craig
Baja 27
You will find Formula very accomodating in the comfort dept. My 2000 382 is fully loaded with Gen Set. It runs mid 70's all day long and is very friendly on you and the passengers when out in the chop.
Like Troutly said they are HEAVY, my buddies 382 has TCM 800's and only hits 100mph on a good day. So unless you have alot of spare change to go fast, buy it for comfort not speed
If you can afford it try to move to an 01 and get the 5 year warranty.
SLINGSHOT
08-18-2003 09:21 PM
