motor change?454 vs 502 >
Old 05-27-2003 | 07:23 PM
excursion's Avatar
Question motor change?454 vs 502
Need some mph numbers. Have 1995 232LS with dual-prop , power now is stock 454/ 330hp. Thinking of motor swap to 502mpi. The boat runs 59-60mph now, wanted to see what the speed would be for a 502/ 415hp. Any help would be great, or if anyone has the same boat with 502 what does it run?
excursion is offline
Old 05-27-2003 | 07:56 PM
mopower's Avatar
Toxic FORMULA
There's a rule of thumb that says "1 mph per 20 HP"
From what I've seen in the 60 mph range that's pretty much true.So figure 63/64 mph.
It's a lot of work and expense for only a couple of mph
mopower is offline
Old 06-04-2003 | 07:43 PM
blown formula's Avatar
A '93 252Sun Sport Cuddy cabin, single 454-450 hp with a Procharger (5# boost) ran 75 mph. That was 23 mph improvement and the fuel economy increased greatly at cruise. The boat carried the bow a lot better with the increased power and made the boat ride much better in the rough. I think the extra power is worth it for that reason alone.
blown formula is offline
Old 06-07-2003 | 08:24 PM
masi242's Avatar
EX, I would put a procharger on it. My friend put one on his 28 sunsation what a diffrence had a 502 it ran about 67 mph now with procharger 82 may be a little more. This will be your best bang for your buck.My guess you could get about 10mph easy.
masi242 is offline
502SCS
0
06-16-2006 07:52 AM
powerguy
27
12-29-2004 01:37 PM
wallynt
1
08-28-2004 02:24 PM
Michael Martin
13
06-19-2003 06:32 PM
Dean Ferry
45
11-11-2002 03:34 PM
