382 Formula "Macerator?! " >
Old 07-18-2003 | 11:04 PM
onebeach
I have just bought a used 382 formula and I can't seem to get the macerator to work! I tryed turning on the power and hitting the switch, but it just kicks the breaker. Im not sure but I thought there is only the Y valve in the back that can obstuct the flow or am I missing something or not doing something wrong!!!
Better yet is there any way to test the unit or see if its clogged?
Im totally lost with the macerator!
Old 07-18-2003 | 11:44 PM
onebeach
Yes it is open
Old 07-18-2003 | 11:58 PM
PhantomChaos's Avatar
Can you hear it running when you push the button in the head?
PhantomChaos is offline
Old 07-20-2003 | 10:34 AM
onebeach
No !!! There is no noise at all , when you push the button!!
Old 07-20-2003 | 07:23 PM
The impeller is probably bad, I'm pretty sure they still use a jabsco macerator, you can but a impeller kit, pretty easy to do other than getting to the unit to get it out.
RonS is offline
Old 07-21-2003 | 08:38 AM
If it's kicking the breaker off when you push the button, it sounds like the motor is seized.
Old 07-22-2003 | 08:56 PM
mcollinstn's Avatar
The motor seal has let doody water get in the front bushing and it has seized the armature. A rebuild kit will contain all your necessary parts.
mcollinstn is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
C_Spray
05-22-2003 11:47 AM
mikesufka
12-26-2002 11:23 AM
