Oil Pressure Gage >
Oil Pressure Gage
Oil Pressure Gage
Old 08-13-2003 | 09:15 AM
BUSTNOUT
Default Oil Pressure Gage
MY OIL PRESSURE LITE FLICKERS WHEN THE OIL PRESSURE SEEMS TO BE OK, IS THIS LIKELY TO BE A PROBLEM WITH THE GAGE,OR SHOULD I BE CONCERNED WITH SOMETHING ELSE? 292 W/ 6.2'S
Old 08-13-2003 | 10:11 AM
Iggy's Avatar
Is the light part of the gauge??
And you say the gauge reads right?
If both are true, replace the gauge.
If the light, by itself, has a seperate sender, replace the sender.
When do you see the light come on?
Is it only at idle? Or when running at speed?
Iggy is offline
Old 08-13-2003 | 03:43 PM
BUSTNOUT
The light is in the gauge and it's come on at idle,and while running. it does seem to be intermitent
Old 08-13-2003 | 10:06 PM
Audiofn's Avatar
Charter Member #232
Are these the Gaffrig Red lines? If so then test the sender, and ground.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-17-2003 | 09:54 AM
Donzilla's Avatar
Bustnout,
I had the same concern with my 02 292 at initial startup you should have app. 40lb. After a run coming back to idle my (Idiot Lite) would flicker also and read lower pressure.Just as your temp will rise! Take it back to 1500 rpm for a few seconds and it is gone.I have asked several different dealerships their oppinion and have got the same response that is characteristic of the 6.2.I also ask about running straight 40 wt. and all said
no. I just keep up on checking oil and am glad to have my extended warranty!
Donzilla is offline
Mikey Likes It
4
03-06-2007 02:15 AM
Rage
2
01-12-2006 02:43 PM
Nordicflame
2
04-13-2005 12:35 PM
Zanie
5
03-10-2005 10:58 AM
Aces & Eights
2
07-01-2003 10:05 PM
