Old 06-08-2005 | 05:09 PM
  #571
Croozin2's Avatar
Question Re: Post pictures of your formula!!!
CMG, mine came with studs. Mine also had the 3" spacers between the manifold and the riser which I think were standard in order for the exhaust to exit correctly for the silent thunder platform. Bill, I don't know your particular setup with the 7.4s but I had to purchase one new riser spacer (OEM Mercruiser part) shortly after I purchased my 311 and the kit came with studs and nuts. It would be very hard to get an accurate torque reading on a bolt that long. Maybe there were different set ups on the Mag and the 7.4. I know the more recent stainless risers used bolts also but the bolts were short because the bolt bosses were cast at the bottom of the riser rather than going all the way through to the top.
Croozin2 is offline
Old 06-08-2005 | 06:35 PM
  #572
CMG's Avatar
CMG
Default Re: Post pictures of your formula!!!
Originally Posted by Bill272
Here's the merc diagram. My 89 with 7.4L's had long bolts (not like the diagram which shows short ones) accessible from the top of the elbow, similar to your pic. Definitely bolts and not threaded rods though.
http://media.stemtostern.com/LSDATA/...R/19378/25.GIF
Bill - thats the same set up I saw just last week on a 272 that had big blocks, but the 311 needs the additional 3" spacer like Croozin said so you don't typically see it in a Merc diagram.
Croozin, am I right that you have 7.4's and not mags?
I figure someone must still have stock set up on a 89 311 w/mags and can confirm.
Chris G.
CMG is offline
Old 06-08-2005 | 09:25 PM
  #573
292SR1's Avatar
Might be different on a 311, but my '89 292 (365 Mags) had Threaded rods and not bolts as shown in your picture.
I know this as I switched to Stainless Marine 2 years ago...........went down to the shop just now to look at the risers/threaded rods. The latter are 7 inches long to accomodate the oil filter bracket, with the rest 6 inches.
Hopes this helps.
Looks like the risers have been off at some point on your pictured engine.
292SR1 is offline
Old 06-08-2005 | 09:29 PM
  #574
CMG's Avatar
CMG
Hopes this helps.
I think 311's engines sit a little deeper in the boat, mine are 10 1/2 on the filter side and 9 1/2 on the others
Chris G.
CMG is offline
Old 06-09-2005 | 07:35 AM
  #575
Croozin2's Avatar
I had Mags in mine but I changed over to EMI Thunders when I did the rebuilds in '03. Mercruiser has some really innovative ideas on some things but the old cast iron manifolds/risers with water flowing in between are so antiquated. It's just a water ingestion problem waiting to happen (which is the major reason I went with the EMI plus dropped about 50 pounds per manifold!). By the time you see a external water leak you've had an internal leak for some time and the damage is done.
Croozin2 is offline
Old 06-16-2005 | 02:54 PM
  #576
resurrected's Avatar
Not going into the water this year. A work in progress
Attached Thumbnails Post pictures of your formula!!!-boat-015.jpg   Post pictures of your formula!!!-resurrection-3-007.jpg
resurrected is offline
Old 06-16-2005 | 02:59 PM
  #577
cuda's Avatar
Where did you get the picture of Audiofn's boat??
cuda is offline
Old 06-16-2005 | 03:03 PM
  #578
Audiofn's looks as hopeless as mine?
Old 06-16-2005 | 03:39 PM
  #579
cuda's Avatar
Audio's will be petrified before it's done.
cuda is offline
Old 06-16-2005 | 04:27 PM
  #580
Audiofn's Avatar
Charter Member #232
HEY THERE IS ANOTHER ONE AS DUMB AS I AM!!!!! MY mom said that they broke the mold.... I always believed her but LOOK THIS IS PROOF!!!!
Attached Thumbnails Post pictures of your formula!!!-42-stringer-grinding-removal-small-.jpg   Post pictures of your formula!!!-27-new-bulkhead-small-.jpg   Post pictures of your formula!!!-63-stringers-all-glassed-small-.jpg
Put your best foot forward!
Audiofn is offline
