removing black strip >
Old 02-27-2004 | 09:43 AM
bowtie89
Default removing black strip
has anyone tried or have you removed the strip of black that goes around the back of the boat! I think it would look much better white!
Old 02-27-2004 | 11:29 AM
I take it the black "strip" you are talking about is the black graphic above the rub rail, right?
SR1 models used imron paint for this graphic, the smaller 206's, 223's and 242's used vinyl graphics (at least most did, some were painted).
In any event, if you remove the black, you will invariably see a shadow where the white has darkened over the years. The white under the graphic will be relatively virgin compared to the surrounding white. Then, you'd have to do a lot, and I mean a lot, of buffing to get the surrounding white up to snuff. Actually, you'd probably have to wet sand it to get it right. That is just tons of work.
I've considered what you suggested about getting rid of the black. But, I only consider it for like 15 seconds or so before I return to reality. The black is staying on mine.
ThirdBird is offline
Old 02-27-2004 | 11:34 AM
rchevelle71's Avatar
To get over the fade issue, you could sand the black, and repaint it any color you wish.
rchevelle71 is offline
Old 02-27-2004 | 12:07 PM
cuda's Avatar
I don't know if it's the same, but I'm taking off the black strip that surrounds the cockpit on this 81. It is vinyl. It came off fairly easily and it isn't much different under it as what is around it.
Before
cuda is offline
Old 02-27-2004 | 12:08 PM
cuda's Avatar
In this picture you can see where I have it removed around the bow and it's still on next to the helm.
cuda is offline
Old 02-27-2004 | 01:06 PM
Iggy's Avatar
If his 206 is like my 206, the black stripe is vinyl.
I thought the same about gel coat color difference too. It'll look brite white compared to the rest.
Iggy is offline
Old 02-27-2004 | 04:45 PM
cuda's Avatar
Mine wasn't that different under the stripe, but the deck is kind of an off white to begin with, not a bright white.
cuda is offline
Old 02-27-2004 | 05:16 PM
Formula Outlaw's Avatar
I didn't like all the black either so I cheated. I used tape and broke the black up that way. I don't have a good picture but will get one asap and post it. It isn't as clean a look as if it were all white, but it's a hell of a lot better than all that black. I broke it up using both white and teal tape. Came out pretty good. It really minimized the "black". Plus I have a couple of decals back there to further draw attention away from the black, including the famous OFFSHOREONLY.COM decal.
Formula Outlaw is offline
Old 02-27-2004 | 08:27 PM
32storm's Avatar
I believe that is Imron paint on that boat, and agree with Thirdbird that it'll be a job to remove it, and get it to match. I would considering either painting over it, or just add color to it and break it up so the black portion is not so dominating.
32storm is offline
mjb
3
04-08-2005 10:36 AM
tomtbone1993
04-27-2004 07:21 AM
