Side panel in the windsheild cracked... >
Old 05-25-2004 | 07:16 PM
CBlakeNS's Avatar
Default Re: Side panel in the windsheild cracked...
THanks man, ill have my parents try them tomorrow
Im sure they are going to need the specs in which I dont have and need to find out...
CBlakeNS is offline
Old 05-25-2004 | 07:23 PM
CBlakeNS's Avatar
Originally Posted by Hi-Tech Marine
Blake, this original post has been here for a while. If you are still following - check out Taylor Made products. The make many OEM windshields and may have a part for you.
Bill Brasher
Allison Marine
Allison Performance Boat Trailers
Hi-Tech Marine Trailers
www.AllisonMarine.us
Yes that is the original manufacturer of the year boat we have, but they said that they dont have the pattern anymore for the window so they cant do it or something???
CBlakeNS is offline
Old 05-26-2004 | 04:43 PM
CBlakeNS's Avatar
Ive contacted like almost everywhere that you guys have mentioned and done everything you have said and no one has the pattern to do it anymore...
What should I do?
CBlakeNS is offline
Old 05-27-2004 | 12:31 AM
RedDog382's Avatar
It's very difficult to believe Taylor Made doesn't have the pattern anymore! Sounds like you need to climb the laddder at both Taylor Made and Formula. Ask them if they could make it if you supplied a pattern. You might also want to check with a custom/specialty glass shop to see if they could make a piece from a template to match the thickness and tempering of the original.
Just for grins, try talking to Dave Gerber at Monroeville Marine @ 419-465-2558 and Robert Nelems (Magicfloat) on this board. They are both Formula dealers.
RedDog382 is offline
Old 05-27-2004 | 08:18 PM
CBlakeNS's Avatar
Magic Float I already pmed he told me to contact a auto glass supply place, I think my dad is going to....
Ill try calling the other guy up also.
CBlakeNS is offline
Old 05-27-2004 | 08:59 PM
Waterfoul's Avatar
Gone Fishin'
well, turns out the pair of glass that was sent (from water bonnet, sounds familiar, now that it was mentioned) was a side front and side rear piece. i replaced the side rear piece and have the side front. it is basically a trapezoid (but not perfectly symetric) it measures 33.5" x 11.5" basically, with edges 45' ed. one edge is 1/2" longer than the other for each dimension. let me know if this will possibly fit.
have not found a receipt yet with phone number, but try this
http://www.marineglassspecialties.com/MainFrame.htm
Rambunctious
Waterfoul is offline
Old 05-28-2004 | 09:59 AM
CBlakeNS's Avatar
Thanks for the link, by looking at the pictures im almost positive they will be able to do it!!
Thanks alot man,
Blake
CBlakeNS is offline
THEKID29FEVER
Fountain
3
06-09-2008 12:24 PM
johnkot
01-04-2005 07:45 PM
CAFormula1
12-16-2004 11:24 AM
TOMMY HIWAVE
Fountain
3
01-07-2004 02:42 PM
