One tach not working >
Old 01-03-2005 | 11:19 AM
Default Re: One tach not working
Russ,
Had the same problem last year with mine. One tach would work sporadically when I agitated it, then it just didn't work at all. Checked/cleaned all connections at gauge and engine, no response. Turned out to be a bad tach. Bought one used of the right type and vintage ('89 VDO) from a guy on this site. Works perfectly!!
Found out later that the movement within the tach is fairly delicate and gets frigged-up after years of service. New vintage tachs from VDO cost a bundle, like 400 bucks!!
So, find a used one. Lots of guys here have swapped out their gauges for new styles. Good luck.
ThirdBird is offline
Old 01-03-2005 | 02:58 PM
Formula Outlaw's Avatar
Thanks guys. I'll try the above suggestions.
For four hundred bucks I'd replace all the guages with Livorsi. Want to at some point anyway. I want white faced, red needle, and black numbers.
Formula Outlaw is offline
Old 01-03-2005 | 03:17 PM
Anybody have trouble with their fuel gauge? Mine went on the fritz towards the end of last summer. IF I remember right, it would stay towards a quarter tank with speratic bounces all over.
DustinM is offline
Old 01-03-2005 | 03:20 PM
Knock on wood (as I knock on my head), that's okay on my boat.
Old 01-10-2005 | 12:51 AM
RedDog382's Avatar
Originally Posted by C_Spray
...Don't forget to check the big round connector where the boat harness plugs into the engine.
I second this one. Pull the plug apart, clean the contacts and coat with dielectric grease.
RedDog382 is offline
Old 01-10-2005 | 06:49 AM
Ran a "continuity" test yesterday. One of the light grey wires, the one that runs back to the dash, failed the test. Checked it to the connector, and okay to that point. So I just ran a new wire from the dash back to the coil, clipped the light grey wire and wrapped and wire tied it to the new wife to designate it's replacement, and the tach is now working perfectly. Thanks for the suggestions guys.
SCARAB98
Wanted
1
05-31-2008 04:37 PM
SCARAB98
Scarab
1
05-30-2008 10:17 PM
SCARAB98
2
08-20-2007 03:34 PM
brian valery
5
07-27-2007 03:52 PM
thespy
1
05-21-2002 11:00 AM
