Unequal drive trim movement
#31
The drives require quite high pressure to trim while accelerating to counteract the thrust. Could be 2000psi or more depending on the type of drive, spacer length, prop pitch, torque at the prop, etc. Tabs would be more reasonable, they can reach high cylinder loads under certain circumstances, but not usually while you are trying to move them.
