Re: 35' Lightning 525SC Numbers
Chambersgc-
So you did some actual grunt work to the motor. Is 86gps what you got when it was stock. I would really like to get mine that high. How does the boat handle at that speed? P.S. maaybe I can get more than 80 if I just start sayin No to people who always want a ride. Know what I mean? and only put like 30 gallons in it, and if it can be 60 degrees. |
flash e ----
you mentioned supercharged 525 EFI's --- what exactly are the blowers and how much boost you talking here ?? tnothin -- stock was 80mph, on a good day -- you need 6-1/4 psi boost min. on fresh water to get 82 - 83 --- i was at 7 psi when i got 86.5 with about 80 gals fuel on flat water |
Chambersgc-
So 80 right now stock is about right. I think I am gonna just do the pulley and the Chiller. And one more question for you: If I do these mods what prop do you think I should switch to and can I stay with my stock XR drive? Thanks again for your help man. |
[QUOTE=chambersgc]flash e ----
you mentioned supercharged 525 EFI's --- what exactly are the blowers and how much boost you talking here ?? We are having whipple superchargers installed. I am not for sure on the amount of boost since our dealer is doing all of the work. |
flash_e --
i am going to guess 100.1 mph at 5-1/2 psi boost with those whipples -- tnothin -- from what i did with my motor, if you change your top pulley to one that is about 3/8" smaller in dia. you should expect about 2 psi more boost and a speed of 83mph (my guess). --- XR drive, NO problem --- if you go over 8 psi, you definitely need the chiller and you need to re-map you fuel system, and can expect speeds near 90 (from what i was told by Joey Griffiin) |
Chambersgc-
Hey thanks man I appreciate it. |
I must say . Maybe a little more seat time dose help. At NYC I was in the throtles all day all types of seas and finished with everyone still on board and the boat running perfect. Leaving for Atlantic City poker run friday. What a country! If your boat dosen't scare you write the check!!!!
A twin step 35 with 525efi on the gun and gps 88mph all day long.
1 Attachment(s)
42 Poker Run Boat, Same Hull As Lightning 525 Efi 97 Fully Trimed
With pro chargers
| All times are GMT -5. The time now is 03:47 AM. |
