Need some advice >
Need some advice
Need some advice
Old 06-07-2005 | 10:59 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Need some advice
Originally Posted by FOUNTAINFAMILY
I was told that Merc. only needs about 3 lbs of pressure to cool properly. My guages read 7 on port at 3800 and 12 on Star. The drives have the low water pic-ups.
You are misinformed. That is not enough pressure to give a complete fill, possibly allowing for air pockets in the heads, and possibly a higher false temp reading because the sender may be registering a steam pocket, not water temp.
Stock HP500's will have around 15-20 at WOT. Since you stated new circulating pump and t-stat, that eliminates a crossover setup which will give low pressure.
Something is blocked/not right. Double check the inlet supply hose from the transom to the sea water pump for blockage or a kink. That hose HAS to be hardwall. You can't squeeze it by hand. Also remove the hose on the outlet side from the seawater pump, then remove the hose end right before going into the t-stat housing and back flush that line making sure no broken impellor parts come out a tthe seawater hose end.
You did install the hoses on the right ports when you replaced the impellor? That will give the symptons you are seeing too. If all checks ok, check the flow from the drive pickup to the seawater pump.
Good Luck
US1 Fountain is offline
Old 06-08-2005 | 11:25 AM
Thanks for the info. I will look into the hose routing and see if there is any blockage anywhere. t we will be on the lake this weekend on sunday.
FOUNTAINFAMILY is offline
Old 06-08-2005 | 01:57 PM
tnothin's Avatar
Hey Fam. Dont you live at Disco. Bay, so what lake are you goin to. I want a ride on your boat Ha Ha but seriousley lets meet up sometime. My name is Chad call me if you want man
916-837-1379 we'll have a cocktail.
tnothin is offline
Old 06-09-2005 | 06:52 PM
We are headin up to Berryesa on Sunday. We have a 4 year old and it will be her first trip out. We live in Green Valley.
screamin_69
Prop Talk
9
04-18-2008 11:35 AM
fountainfevr
Fountain
11
06-13-2007 10:33 PM
nolimits
Fountain
48
10-08-2005 08:57 PM
SLINGSHOT
05-16-2002 07:33 AM
