Stupid Newbie Question..... >
Old 06-14-2005 | 12:44 PM
Dago Racing's Avatar
Default Stupid Newbie Question.....
I know this might sound stupid but I have to ask...........where does the water drain to out of the cabin cooler? I assume it goes down to the engine hatch but I'm probably wrong.......so I must ask the pro's.............thanks in advance!
Dago Racing is offline
Old 06-14-2005 | 03:31 PM
Fountain38SC's Avatar
Default Re: Stupid Newbie Question.....
I don't have a cooler in the cabin but my guess would be it drains thru a thru hull fitting. Easy way to find out would be to put some water in it and take a look. Just my .02
Fountain38SC is offline
Old 06-14-2005 | 04:12 PM
On my Fountain, it comes out the thru hull fitting just outside from where the cooler is.
88Fountain is offline
Old 06-14-2005 | 04:18 PM
Fountainclimber's Avatar
It just drains into the bilge. Really.
F
Fountainclimber is offline
Old 06-14-2005 | 05:07 PM
It should drain thru a thru hull fitting, not into the bilge!!!!
wcmarine is offline
Old 06-14-2005 | 06:21 PM
blownincome's Avatar
Bilge.if not the sink would back up into it.
blownincome is offline
Downtown42's Avatar
That's where it's at on my old 1993 35 and the new one.
Downtown42 is offline
Old 06-14-2005 | 06:41 PM
tnothin's Avatar
My drains on the side of the hull where the cooler is. Not through the bilge.
tnothin is offline
Old 06-14-2005 | 09:27 PM
My dads last 35 was the same way.
jmeng is offline
Old 06-14-2005 | 11:24 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Sounds like all of the above. My '99 32' drained into the hull right at the gas tank. Problem was, there is no drain holes for that compartment. I ran a hose from the cooler, between the floor and stringers, then out 1 of the drain holes in the engine compartment forward bulkhead. I don't like ANY water to get in the bottom of the hull. Not convinced all water will drain out. Always seems to be 1 drain hole or so that doesn't get drilled in the very bottom of the compartment holding water back.
US1 Fountain is offline
