clearance issue for exhaust >
Old 06-15-2005 | 07:21 AM
briana's Avatar
Default clearance issue for exhaust
Can anyone tell me what aftermarket exhaust I can use to replace stock on a 99 32 fever with 502's. without modifying the engine hatch.
cmi? gil?
briana is offline
Old 06-15-2005 | 11:05 AM
Default Re: clearance issue for exhaust
Give Jeffrey Becker at CMI a call...920 720-4225
Back4More is offline
Old 06-15-2005 | 02:43 PM
p4-33's Avatar
Also make sure you know what your motor centerlines are at. My 10-Meter's motors sit at 33" OC, and that limits my exhaust choices a LOT. I'm running IMCO Powerflows, and I think my only other choice would be Stainless Marine's for 33" centers.
Most of the nicer stuff, CMI, Stellings, etc needs 34 - 34 1/2" minimum. I also understand that Lightning can make custom sets for tight clearances.
Measure between the leading edges of your drives, and that will tell you where you're at.
Good luck,
Brian
p4-33 is offline
Old 06-15-2005 | 03:08 PM
Lofty's Avatar
briana,
I had Lightning make up a set for my 8.8. They work great but did require some notching of the hatch to get it clear. They'll make a lower set for you if you give him the measurements. Make sure you talk to Jan.
Brian.... You're pulleys are still sitting here. I haven't forgotten
Lofty is offline
Old 06-15-2005 | 03:31 PM
p4-33's Avatar
p4-33 is offline
Old 06-17-2005 | 10:20 AM
jrz
CMI E tops or sport tubes will fit a 33" center with a stock head.
jrz is offline
Old 06-17-2005 | 11:21 AM
EWB
I put Keith Eickert exhaust on my 94,32 without having to do anything.
EWB is offline
Old 06-28-2005 | 09:43 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
cmi? gil?
I am replacing mine now with an older set of Stainless Marines. Also a '99 32' 502's. I have the silent choice. For the most part, an easy swap. Got 1 manifold swapped before ran into a slight snag. I have to rework the oil filter, drive bottle mounting bracket though to clear the manifold to riser water hose. The other side is no issues. No problem with the hatch because the risers are same height as stock.
Stock cast iron manifold and risor..... 65# each
SM alum manifold and risor.... 20#
US1 Fountain is offline
russ
0
07-21-2005 04:35 PM
Formula Outlaw
12-26-2004 05:07 PM
waterbum
6
10-22-2003 02:47 PM
JimmyBaja
4
08-11-2003 09:40 PM
