Oil temp
Old 06-16-2005, 08:12 AM
Registered User
35 White Lightning's Avatar
Default Oil temp
What is a normal oil temp mine gets up tp the 240 rage crusing then at an idle drops to around 200 is this normal. 502 Mag mpI on a 93 27 fever
35 White Lightning is offline
Old 06-16-2005, 10:05 AM
Summer Heat's Avatar
Default Re: Oil temp
I can only offer 500efi... max 190 cruise 160
Summer Heat is offline
Old 06-16-2005, 11:13 AM
Same here for 500EFI, 140-160 cruise, 180 max. Not sure why it doesn't go above 210F to boil off condensate, but not sure where the oil temp is measured (pre cooler or after cooler). That may explain the differences.
bob_t is offline
Old 06-16-2005, 11:20 AM
Our 96 27 fever used to run the same way. 235 cruising then it would drop to 190 or so. Never had any problems, but i did change the oil every 10-15 hours. hope this helps
FOUNTAINFAMILY is offline
Old 06-16-2005, 11:49 AM
gferdon's Avatar
I complained about high oil temp on my twin 6.2 MPI's 230 @ normal cruise and 260 @ WOT. Delivery sheet showed the same numbers and Mercruiser says it's OK as well. My friend with the same boat but a 525 EFI runs very low 190 Max. MY .02...
gferdon is offline
Old 06-19-2005, 01:26 AM
FOUNTAINATLAST's Avatar
I'm running a 496HO at idle oil temp is around 120 under moderate driving gets to about 150, under long hard driving runs it gets to about 200.
FOUNTAINATLAST is offline
Old 06-23-2005, 12:15 PM
oblvnxprs's Avatar
Redline, I have the same exact boat and the same problem
I am changing my remote oil filter and adapter to a 540 bulldog unit with a thermostat because this was a problem with our engines also I am switching all of my oil lines to #12 hose with aeroquip fittings I should have everything in this week and will let you know how I make out
oblvnxprs is offline
Old 06-23-2005, 05:55 PM
Orion 27Fever's Avatar
01 502MPI, 190 degrees max. It usually runs around 160.
Orion 27Fever is offline
Old 06-27-2005, 08:28 PM
Registered User
Let me know if this helps, my oil pressure starts dropping when the oil gets real hot.
Velocity Vector
0
04-03-2008 01:45 PM
GoCiggie31
7
08-19-2007 06:07 PM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
kook
05-15-2002 06:05 PM
Quick Reply: Oil temp
