Dumb question-Flushing motors >
Old 09-04-2005 | 09:16 AM
Downtown42's Avatar
Default Re: Dumb question-Flushing motors
Originally Posted by Jnewton
When I connect the hose to my flush setup it drips water all over my stainless pipes and the top of the rear engine. You know we can't have that!
Plus I have to climb into the engine compartment to turn the ball valves for each engine... and then remember to turn them off.
On the trailer, I'm using the muffs without covering the holes in the bullets. Much easier. Is this a problem? The engines seem to get plenty of water and stay cool idling on the muffs.
Any advice?
I agree. Muffs are much easier and no water drips on motor.
Is it best to punch a hole in the oil filter before removing? Oil gets all over otherwise. 525's
Downtown42 is offline
Old 09-04-2005 | 10:08 AM
Registered User
Def punch a hole in the oil filter and let it drain into oil pan. Merc sells an adapter that covers the nose cone of the drive. it is a little rubber cover with a strap that goes around the drive ... real easy to use. If anyone needs one just e-mail me at [email protected] and I will get you a price and ship it to you. Or check with your local merc dealer!
- Vinnie
HPFountain is offline
Old 09-09-2005 | 07:41 PM
H2Xmark's Avatar
I have had good luck by using muffs on the side pickups and on the bottom pickups I cut some squares out of an old inner tube a little bigger than the holes on the bullet, then go over the rubber piece with 2" wide masking tape, it stick great, I sometimes put a little bit of grease on the rubber to bullet side for better sealing,
H2Xmark is offline
Old 09-10-2005 | 12:37 PM
offshoredrillin's Avatar
On my Tiger the fresh flush is on the starbord side, I love it, let it run for a bit to fluch the drive, then crank up the motor. put the cap back when done on or it will create a vacum at the impeller.
offshoredrillin is offline
Here's Johnny
07-18-2007 02:30 PM
Viper TT
07-07-2007 11:08 AM
PhantomChaos
35
01-01-2007 06:44 PM
formula1
12-04-2003 08:56 AM
pozguy
0
05-27-2003 01:00 AM
