Removing the Vinyl Graphics ?? >
Old 08-25-2005 | 08:17 PM
Default Re: Removing the Vinyl Graphics ??
Nope, that just did not work. Razors and plastic scrapers got the chunks off. A bunch of different chemicals each got more off. Several different polishing compounds made things better and better.
But when you look at the boat when its very shiny, polished, and waxed, the location of the old stickers is obvious -- its visible. You can't feel it, and you can't see it looking straight at it, but its very clear looking at it from an angle: the reflection of the trees is clearly different.
u4ea32 is offline
Old 08-26-2005 | 03:11 AM
3M glue and adhesive remover
bug and tar remover
3812 enamel reducer
any of these,keep it wet and out of direct sunlight.
scrape with a sample formica chip (Lowes or Home Depot) that has been sharpened on bottom edge only like a wood chisel. Sharp and safe on gel.
Wet sand gel w/ #1200 then #1500 after glue is removed.
Buff w/white compound pad and white 3M Imperial Compound and watch it shine! Don't forget to wax.
BTW, PPGs' Deltron replaced Imron over 5 years ago. G$
Gmoney52 is offline
Old 08-26-2005 | 07:47 AM
Dago Racing's Avatar
Does anyone know where I can get a a white rubrail ?
Dago Racing is offline
Old 08-26-2005 | 07:56 AM
birdog's Avatar
Thats not the glue....Just faded more...Sometimes you just cant get it all out. Is it white or a color ?..Colors are worse
birdog is offline
Old 08-26-2005 | 12:34 PM
WD40 was always a good glue remover for me...and I agree with Lofty, the rub rail was a *****.
Back4More is offline
Old 08-27-2005 | 12:00 AM
Originally Posted by Lofty
I can get you new rub rail but it will run about $1500 to wrap the whole boat. It's not an easy job either. Think long and hard about replacing it yourself. As far as the graphics go. Ripp them off! These guys are right, the glue will come off and with the 3m buffung compound and maybe in a severe case, some 1500 grit wet/dry. It is a big job but nothing you can't handle. That boat looks GREAT all white.
I might take you up on that rub rail. Just out of curiosity has anyone painted one ? Sounds alot cheaper and EASIER!! LOL!
Old 08-27-2005 | 03:54 AM
bug and tar remover
3812 enamel reducer
Thanks! I'll try this.
u4ea32 is offline
Old 08-27-2005 | 02:56 PM
carb cleaner works better then anything out their for getting the glue off.
joew. is offline
Old 08-27-2005 | 03:46 PM
Hydrocruiser's Avatar
Arrow Re: Removing the Vinyl Graphics ??
Get a heat gun...warm up the vinyl until it's pretty warm..it peels off adhesive and all for the most part.
Hydrocruiser is offline
Old 08-29-2005 | 09:15 PM
bryanspeedracer's Avatar
I ordered 80 ft. (4, 20 ft. sections) to redo my 10 Meter's rubrail. I bought it from Rubrails.com and it cost me about $300 dollars. I bought new stainless fasteners (#10 screws, washers, and nylock nuts) for another $25 bucks or so.
Removing the old one was more of a chore than installing the new one.
I'm shocked at the $1500 figure. Even if materials cost $500, a grand is alot in labor.
I do have to forwarn you though, some of your cabin upholstery has to come out and the seats/side pannels in your cockpit.
I used a heatgun a bucket of water and a large towel.
Going around corners isn't too much of a chore. Take your time heat slowly and evenly. When the rail is in the position that you want, the damp towel will set the plastic and hold the new shape.
See, no sweat.
bryanspeedracer is offline
