Need help with exhaust........... >
Old 11-10-2005 | 05:36 PM
Panther's Avatar
Frank's Marine Service
Default Re: Need help with exhaust...........
Originally Posted by jrz
If you have enough room between the top of the inner transom plate and the bottom of the swim step we might be able to modify the tails to exit much lower, and improve the downward angle of the tail. Another option might be to turn out the front engine tails and or headers (what we call bat wing style) similar to the current large engine Fountain factory headers.
jrz, I think his problem isn't with reversion as much as water ingestion.
The header system he has dumps the water at the end of the pipes, above the swim platform. Since the a$$ end of fountains are so low, water easily washes up over the back of the platform and into the exhaust pipes.
Also, over time I guess the headers have cracked and water has gotten into the motor while it has been running.
The boat originally had Gil Offshore exhaust and it exited under the swim platform and out thru the side of the swim platform.
You could run the bat wing style and the two aft motors under the platform and there shouldn't be any reversion problems because the fountain swim platform acts as a cap and won't let the water flow back up into the pipes when the platform goes underwater.
I hope that made sense...
Panther is offline
Old 11-12-2005 | 04:08 PM
I have two sets of exhaust headers for sale. Call me at 336 214 6900 Roger
Roger is offline
Old 11-12-2005 | 08:47 PM
tomtbone1993's Avatar
are they like what i currently have? thanks, Tom
tomtbone1993 is offline
Old 11-14-2005 | 09:12 AM
Tom Call me discuss the headers 336 214 6900 (cell) Roger
Roger is offline
Old 11-14-2005 | 09:13 AM
Tom, After looking at the pictures of your boat I do not think they will work without tailpipe work. Roger
Roger is offline
Old 11-14-2005 | 10:28 AM
jrz
The headers you have could be duplicated, but by exiting under the swim deck it would help the reversion problem by creating much more drop, and you would have to plug the existing holes.
jrz is offline
Old 11-14-2005 | 11:30 AM
What would you recommend if, I go under my swim platform?
Old 11-14-2005 | 11:46 AM
10x's Avatar
10x
10x
Tom... I also have stellings with straight tails exiting over the rub rail. To eliminate the reversion problem, I've welded about a 6" piece of 3/4" stainless tubing that I got from stelling, to my existing stingers.
They stick out past the mufflers about 2"s. To do this, I had to take off the baffle plate in the muffler, and mill a horseshoe lookin U shaped slot into the top of the plate so the stinger can stick through when the muffler is in the closed position.
When the boat is sitting still and a wave hits the back of the boat, as long as the mufflers are closed, barely any water will get past the baffles, as long as you don't mill that opening at the top way too big.
If you need some more advice on how this was done, call me at home tonight, 708-579-5434, or on the cell during the day 708-870-2572..........Frank
I'm gonna see if I have any pics of this up close, not sure till I check.
Attached Thumbnails Need help with exhaust...........-double-stack-vents-02-.jpg   Need help with exhaust...........-image00139.jpg   Need help with exhaust...........-image00150.jpg
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 11-14-2005 | 02:06 PM
jrz
Yes, I would exit under the swim platform. The best way to do this is to bring the boat to CMI and have the headers and tails made to exit through the original holes.
jrz is offline
Old 11-14-2005 | 02:10 PM
Will you drill the holes? Would you prefer the motors in or out?
