Fountain trim
I have the crt trim on the wheel. I want to get rid of it and put the trim on the throttle. Has anyone done this? Is it difficult?
Thanks |
Re: Fountain trim
I am wanting a new Steering Wheel, What is easier? keeping it on the Wheel or putting it on the Throttles.
Re: Fountain trim
Re: Fountain trim
jryan
The trim on the wheel I thought was for the K planes and the outdrive trim is on the throttle. Is this what you are talking about or something different? WILL |
Re: Fountain trim
Originally Posted by Rare Breed
The kind of TRIM I usually see you with is usually on you or Big Mikes Gear Shift!!!
Re: Fountain trim
Originally Posted by 27Fountain
jryan
The trim on the wheel I thought was for the K planes and the outdrive trim is on the throttle. Is this what you are talking about or something different? WILL I didnt know how difficult either option was to install. Thanks for the Help. |
Re: Fountain trim
You can set it up either way. If you decide to pull out the entire CRT setup you could sell it as they are pretty nice. The trim on the throttles is just a quick wire up and some diodes. Depending on what throttles you have some are adaptable to add trim switches. Pm me if you want more info.
Re: Fountain trim
Re: Fountain trim
You can change over your single in-throttle switch to a dual switch setup, 1 for drives, 1 for tabs. I'm doing this right now.
What brand levers do you have now? |
Re: Fountain trim
Oops sorry. What was I thinking. Duh!
Here's your Fountain Trim :evilb: |
| All times are GMT -5. The time now is 10:39 AM. |
