Sea Water Strainers >
Sea Water Strainers
Sea Water Strainers
Old 02-26-2006 | 09:32 PM
Default Sea Water Strainers
Hey... someone should warn us... 525 freshwater cooled should always... always have seawater strainers!
The salt water passes through three heat exchangers that are just very small copper tubes. The least bit of seaweed or debris will clog them. Then it's a long hard job to get them cleaned out again. I learned the hard way!
Now I need a recommendation on sea water strainers. While I'm putting them in, I would like to have a cool color... maybe blue to match the 525's?
Who makes some good ones that are easy to sight when clogged and easy to clean out?
Thanks for any recommendations... JON
Jnewton is offline
Old 02-27-2006 | 07:18 AM
Registered User
Default Re: Sea Water Strainers
I like the Perko strainers ... I use a 1 1/2" inlet which is way over kill, but never have to really clean them and they hold so much water that even when you come out of the water your pumps don't run dry. I think they are the easiest to cleanbut only come in bronze.
HPFountain is offline
Old 02-28-2006 | 07:11 PM
UNSANE's Avatar
I just bought a 29' with a 525, it comes next Monday but I'm pretty sure there are no strainers. How much did the Perko cost and where did you get yours? thx
UNSANE is offline
Old 02-28-2006 | 08:42 PM
blownincome's Avatar
www.trickmarine.net Fred will set you up!
blownincome is offline
Old 03-11-2006 | 07:09 PM
monstaaa's Avatar
prkos work better on slower boats.
hardin marine makes the top strainer for looks , use , and durability. plus there easy to clean.
monstaaa is offline
Old 03-11-2006 | 09:17 PM
beachbob's Avatar
how about 496ho's should u have them? I was told that they are not really needed? Is this true. TX for any info in advance.
beachbob is offline
Old 03-12-2006 | 07:54 AM
DragonFire's Avatar
You don't need it.... Till you should of had it !!!!
Take a ride on a boat with a good viewable strainer and check out what's in there after the ride..
Once you have one, you will never have a boat without one...
Good Luck !!!
DragonFire is offline
Old 03-12-2006 | 10:35 AM
Downtown42's Avatar
Interesting thread. I'd go with red ILO blue.
Downtown42 is offline
CcanDo
9
11-11-2007 12:21 PM
Smitty
06-28-2005 05:23 PM
Stormrider
05-02-2005 09:10 PM
Daryl
7
03-16-2003 08:51 AM
NEVRENUFF
06-14-2002 12:05 AM
