Gasoline stains - need advice >
Old 08-12-2006 | 04:05 PM
Default Re: Gasoline stains - need advice
I've used Barkeeper's friend on gas stains for the gelcoat, it worked for me.
88Fountain is offline
Old 08-15-2006 | 08:42 AM
gferdon's Avatar
Used the acetone on the rubrails and it worked perfectly! looks like new...it did not work on the gelcoat tho. I tried some compound I had in the garage and it did nothing. I will try the 3M by hand and then use the wheel if necessary. 88 F, I did try the barkeepers friend with no luck. Thanks again to all!
gferdon is offline
Old 08-15-2006 | 05:13 PM
frenzy's Avatar
Unfortunately, you are going to have to buff the compound. If you're unsure about doing it yourself, find a detailer (auto or boat) to do it for you. Might cost you $20.00 or a couple of beers for a friend!
Be sure to use a conditioner on your rubrail any time you use acetone on it.
Good luck.
frenzy is offline
Old 08-15-2006 | 05:50 PM
Good luck.
you have good wax.. how do i get dealer price?
customryder is offline
Old 08-15-2006 | 07:08 PM
frenzy's Avatar
E-mail me your phone number and we can discuss it.
Thanks for the compliment.
frenzy is offline
Old 08-15-2006 | 08:28 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Used acetone on my old rub rail insert. While it cleaned it like new, it also seemed to be more prone to getting dirty easier. That was using the acetone very sparingly too, not drip wet rag.
New insert, now I only use bleach white on it when it really needs a good cleaqning. So far still good.
US1 Fountain is offline
Old 10-28-2006 | 06:55 PM
35 fountain's Avatar
Good God - I did the exact same thing - little brown stains running down the sides. Seems to me that a combination of FSR and Castrol purple cleaner degreaser and waxing it 5 or 6 times with raindance wax took care of it. Thats the last time I fill it up when I come back.
35 fountain is offline
Old 10-30-2006 | 07:38 PM
rjcardinal's Avatar
The rubrail on mine is stained exactly like you describe. A light buff took it off the fiberglass but I had to lightly wet-sand the rub rail then polish it back out. Took a lot of work and finess. Now its stained again and Im going to leave it for a while.
rjcardinal is offline
Old 10-31-2006 | 06:21 PM
Hauling Trash's Avatar
Lightly wet sand
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
SPEEDFREEK
Detailing, Painting, & Fiberglass
2
05-01-2008 12:46 PM
baja27
06-19-2006 07:07 PM
always wanted
13
04-14-2005 07:03 PM
Stormrider
05-24-2004 02:02 PM
26ZX Donzi
17
05-13-2004 12:47 PM
