Messy Oil Filter Removal >
Old 08-23-2006 | 03:35 PM
Default Re: Messy Oil Filter Removal
the screwdriver thing is very good but the filters are still a ***** to get at. The relocating kits solve everything once and for all forever. They can probably be found on the net with a little serching. I'll see if I can find a site and post it. I do not have pictures of my past set up which was very slick (no pun intended) Both filters were located side by side eliminating the fact that One is on the oposite side of the engine than the other.
bgriff is offline
Old 08-23-2006 | 07:12 PM
Thumbs up Re: Messy Oil Filter Removal
Here is an exam[le of a kit to do the relocation job.
http://www.amazon.com/gp/product/B00...705?n=15684181
This can be installed anywhere you want but I would not install them higher than the engine location so that the oil will run out of the lines when changing the oil.
bgriff is offline
Old 08-23-2006 | 08:25 PM
I use the "punching the hole" technique and it works pretty well on my 500's. They are easy to get at. If I were you I would remote mount them and put them right-side-up. I did this with my last boat. Nice thing was I could pre-fill the filters with oil.
Why does Mercury mount the filters upside-down anyway?
innthered is offline
Old 08-24-2006 | 08:32 AM
BAJA WILL's Avatar
Registered User
I pop a hole in them with a screw driver also, works well.
WILL
BAJA WILL is offline
Old 08-24-2006 | 10:47 AM
J.B. Marshall's Avatar
JB Marshall
Yea, Good question?
"Why does Mercury mount the filters upside-down anyway"?
J.B. Marshall is offline
Old 08-24-2006 | 12:19 PM
I use an old laundry soap plastic container cutting off 3/4 of the top keeping the handle. Large enough to put under the filter and catch 99% of the oil from the filter. Kind of like a fishermans piss bucket. A quick wipe and your done.
z.zuperboat is offline
Old 08-24-2006 | 05:16 PM
if there upside down and above oil pan heigth would they not be empty?
Allen
29scarab10 is offline
Old 08-25-2006 | 01:31 PM
Downtown42's Avatar
Originally Posted by J.B. Marshall
Yea, Good question?
cause reggie says you'll go-faster
Downtown42 is offline
Old 11-22-2006 | 02:24 PM
Sydwayz's Avatar
Forum Regulator
Allen
If you have a quality filter, it will have an anti-drain back valve which HOLDS oil in the filter for lesser time of dry-start-up. You do NOT want the filter to be empty.
Hence: Fram = Junk
Wix Racing/Napa = Quality
Sydwayz is offline
Old 01-01-2010 | 02:51 PM
sleek1's Avatar
I just changed my oil. I used K&N oil filters, punched a hole in the top and they did not drain. Anyone know why?
sleek1 is offline
