Rub Rail not centered >
Old 12-13-2006 | 09:58 PM
  #51
OL40SVX's Avatar
Default Re: Rub Rail not centered
Here they are
Is this your buddies boat?? If so it's looks great!!!
http://www.offshoreonly.com/esvon/page-12792.html
Attached Thumbnails Rub Rail not centered-hustlerside.jpg   Rub Rail not centered-kleitz_scooter_002%5B2%5D.jpg
OL40SVX is offline
Old 12-13-2006 | 10:23 PM
  #52
ACTIVESHACK's Avatar
Originally Posted by epeek
Here is my Fountain story. Bought a new 35x in Aug of 05.
After running it around for 2 weekends I had a small list
of items and 1 major problem. The boat listed to port.
What did they do to correct the listing problem? My 05 35x used to list to the port also. I used to keep the anchor and tool box on the stbd. side,water tank almost empty and still had to run the port tab down all the time.
ACTIVESHACK is offline
Old 12-13-2006 | 10:49 PM
  #53
The listing problem is most likely water getting up past the engine box bulkhead up under the tank area and not draining back out cause of all the saw dust, fiberglass coreouts, carpet scraps, tank foam and other chit clogging up the 1" drain line on that side.
Get the bow as high as you can and use some fish tape to see if its clogged.
Back4More is offline
Old 12-14-2006 | 06:06 AM
  #54
fastoys's Avatar
yea.thats the outerlimits. Awesome boat! I dont know how you choose when leaving the dock. Both gorgeous boats. Whats faster?
fastoys is offline
Old 12-14-2006 | 09:27 AM
  #55
blownincome's Avatar
Originally Posted by Drag 'N' Ass
No local dealer, live in Michigan. What I mean by the rail not being centered is the seam is not lined up with the stern light or the center of the transom. The seam is about 18" left of center. There is no Fountain logo cover over the seam, thank goodness fot that because it would make it look worse than what it is.
All I wanted from Fountain was a piece of rub rail and that would of taken care of the situation. I will still have it fixed then I will be able to consider my Fountain a one of a kind.
If all you want is Rub rail Let me know you hull ID # and I will have fountain send you watt you want..
Done!
Bob
The center trim piece is avalable from Pachangala on the board
blownincome is offline
Old 12-14-2006 | 09:55 AM
  #56
OL40SVX's Avatar
The Hustler is faster being the Whippled 500's. The Cig is plenty fast though at 92.9 mph.
OL40SVX is offline
Old 12-14-2006 | 06:07 PM
  #57
fastoys's Avatar
Are the whipples dependable? Any drive issues? How much MPH gain? Did you have to re prop? EFI?
fastoys is offline
Old 12-14-2006 | 06:16 PM
  #58
OL40SVX's Avatar
The whipples are very dependable with the efi's. The first year we had it, it was just a turn key. We bought the boat with all the work done to it. It was done by Bob Teague on the west coast. He said the boat ran 100 when new. We have seen 95, but we have just rebuilt the motors and haven't gotten any real numbers yet. The stock 500 boats ran 83-85 mph so it picked up 15mph. The drives were switched to 1:36 ratio to accomodate the power. We are running 30" 4 blades.
OL40SVX is offline
Old 12-18-2006 | 11:26 PM
  #59
fastoys's Avatar
Sounds like a sweet set up .A friend is putting whipples on a 2005 42 fountain with 525's. Curious 2 see how fast it goes.
fastoys is offline
Old 12-19-2006 | 12:12 AM
  #60
Downtown42's Avatar
Me too. Can you remember to update us on this? Thanks.
Downtown42 is offline
