Bow rail removal >
Bow rail removal
Bow rail removal
Old 02-06-2007 | 03:08 PM
Ran-Dom 32's Avatar
Default Bow rail removal
how bad does this screw up your headliner? Was thinking of taking them off & having them powder coated. Is there a way to gain access to the bolts without pulling back the H/L?
Ran-Dom 32 is offline
Old 02-06-2007 | 03:19 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Bow rail removal
All my bolts are up behind the side light trim panels and behind the counter plastic/ceiling trim. I had the trim section off that goes on the bottom side of the upper plastic panel, so a couple of those bolts where easy to get to then. 1 rear most bolt drivers side, I did have to pull down the ceiling in the closet to access it. That headliner is just double sided sticky chit. Stapled back up when I reinstalled. None above the headliner itself. Feel up behind the panels. Several of my bolts had a FG layer over them and had to be cut out, so look close. The rail is put on before the top half is mated to the hull. I think the deck to hull joint joining was the reason for the FG over the bolts.
A buddy did his 42 Lightning, and had same methods as my Fever. Takes 2 people. Those rails will want to straighten out as you remove them, so need someone on the outside to hold it while you unscrew it to keep it from moving and scratching the boat.
US1 Fountain is offline
Old 02-06-2007 | 04:37 PM
ALL IN's Avatar
i also have mine powdercoated blue and that is great advise on 2 people.it is not a bad job just make sure you seal it up when you put it back together.good luck!!!!!!!
ALL IN is offline
Old 02-06-2007 | 05:30 PM
P Offshore's Avatar
I have a set powdercoated white off a 42' I did not put them back on so they have been hanging in the shop foe 2 years. Let me know if anyone wants them.
P Offshore is offline
Old 02-06-2007 | 05:43 PM
nocigarette's Avatar
i have been looking for one for my mag....how long is it and how far off the deck, color too............Pics if ya got them
nocigarette is offline
Old 02-06-2007 | 06:29 PM
tomtbone1993's Avatar
P Offshore what color?
tomtbone1993 is offline
Old 02-06-2007 | 07:35 PM
BZ's Avatar
BZ
yeah what color????
BZ is offline
Old 02-06-2007 | 08:08 PM
Fenderjack's Avatar
Pirate of the Chesapeake
The ones that P OFFSHORE has looks to be white..
John
Fenderjack is offline
Old 02-06-2007 | 10:22 PM
Ginger or Mary Ann?
Originally Posted by P Offshore
I have a set powdercoated white........
Just a guess, but ......
Old 02-08-2007 | 02:44 PM
Downtown42's Avatar
I re-did my white factory rails (they chipped really easy) done with "Metal-Loc" Dupont paint by a body shop. We use this for custom painting of aluminum fuel tanks on semi trucks. Holds up better than powder coat and the ladies won't chip the rails with their jewelry and rings.
Downtown42 is offline
