Steering Wheel Buttons and Hub
have you ever had problems with your trim not working.i have the trim buttons on my wheel,and it does not work.i was told that in the hub there is brushes,or contacts in the hub that needs to be cleaned.is this the type hub/button set up you have?
Yes it is. There are 5 brushes on the bottom of the steering hub that can be unscrewed. As far as cleaning the hub it is also very easy to remove just remove the wheel and there is a single nut on the shaft, once removed the hub will slide out. However you may need a puller to get it off. Let me know if you need anymore info, cause I just went through the same battle last week.
I definatly need one. My 32 had it and I loved it. My 35 does'nt and I was go to swap it over. Let me know how much and how to pay and I will have you ship it when you can. You can reach me at 518 441-5379.
Thanks Dan
Thanks Dan
