1 Attachment(s)
I got your high flow fittings right here. Check out Fountains high flow fuel system... that we are removing. The std. 90*s are apart of the kit from Whipple.
Originally Posted by ExcaliburHawk40
(Post 2104462)
(Post 2104462)
Holly shet!!!!!:eek: Thats bad |
what is bad, what are high flows?
2 Attachment(s)
Originally Posted by louie0611
(Post 2105211)
The pick of ExcaliburHawk40 posted of your fuel valves.He said he was changing them. Ive never seen anything like that . I wonder if Fountain puts those on the higher HP boats???Your in good hands. They know what there doing . I am not to good on explaining this kind of stuff.The 90 high flow is a tube that is bent ,the other is a 90 elbow type fitting it is drilled from each end so in the inside the fuel flow hits a wall and restricks flow and or could aerate it if there a sharp edge , in theory? #2 http://www.gnetworks.com/v4files/bar...0rev2%2006.pdf http://www.patentopedia.us/percussio...n_liquids.html http://www.magnafuel.com/products/ac...ings/index.htm |
interesting, thanks for the info.
1 Attachment(s)
(Post 2105166)
can you explain more, what we are looking at? Thanks, Tom
(I have the tanks backwards in the picture) |
thanks for the explanation:cool:
when will the dyno start?
Did my engine break your dyno machine,
| All times are GMT -5. The time now is 03:52 PM. |
