Prop help
Old 08-17-2007 | 04:14 PM
jryan26's Avatar
Default Prop help
The boat is a 35 single step 750-800hp. 1.36 gears -2 lowers with 30 labbed maximus props. I keep reading about removing the diffuser ring. How much of the ring should I remove?
jryan26 is offline
Old 08-17-2007 | 08:46 PM
monstaaa's Avatar
a little
monstaaa is offline
Old 08-17-2007 | 08:47 PM
jryan26's Avatar
I will remove 1 1/8th inch.
jryan26 is offline
Old 08-17-2007 | 08:58 PM
monstaaa's Avatar
too much
monstaaa is offline
Old 08-18-2007 | 08:18 AM
jryan26's Avatar
Monstaa
Why do you say that is too much? That is exactly how much a guy with the exact same set-up as me removed and gained 5mph. Same hull same horsepower, same drives, same props.
jryan26 is offline
Old 08-19-2007 | 09:30 AM
monstaaa's Avatar
it indeed will make the prop faster, however you will sacrifice other characteristics of the prop which are more valueable. for one stability at high speed. by triming less, in other than pancake flat water the boat should be just as fast, or a tick slower due to its ability to remain stable while at the same time reducing drag and not diverting thrust.
monstaaa is offline
Old 08-23-2007 | 03:50 PM
throttleup's Avatar
This can be very true Monstaaa. Much easier to take one off then to put one back on! Be conservative with removal.
Julie
throttleup is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
