Dry tail pipes >
Dry tail pipes
Dry tail pipes
Old 05-19-2008 | 10:15 PM
aTX427's Avatar
Default Dry tail pipes
Are there any shops out there who can modify my three piece tail pipes to a singe piece dry or do I have to have a new set made?
These actually have a silicone coupler on the inside that you can see in the pictures, then have a tips that slide in from the back of the transom. If the coupler loosens the tip can slide out and exhause / water dumps into the bilge. Had it happen over the weekend and it made a mess.
aTX427 is offline
Old 05-21-2008 | 07:35 PM
monstaaa's Avatar
you will need to make new ones, and install dumps for the water exiting the new tails. will be quite a bit louder.
monstaaa is offline
Old 05-22-2008 | 12:31 AM
MM1
The louder the better.
MM1 is offline
CcanDo
24
07-03-2007 08:39 PM
GS42fun
2
06-06-2005 07:18 PM
baja36ft
8
02-06-2005 03:14 PM
Strip Poker 388
09-10-2002 08:44 PM
