where to mount gps >
where to mount gps
where to mount gps
Old 08-03-2008 | 05:14 PM
Default where to mount gps
i wanna mount a garmin gps in boat and was wondering where people are mounting it for a nice clean installation any pics or info would be greatly appreciated.
fountain07 is offline
Old 08-03-2008 | 05:30 PM
I got a garmin portable mountable with suction mounts above the dash. It looks fine, works great and didn't come loose even in 8 footers on a brutal 400 mile trip. Best of all it's removable and can be used in other boats or vehicles.
fountain 47 sc is offline
Old 08-03-2008 | 06:10 PM
wht model do you have ?
Old 08-03-2008 | 09:25 PM
here.......easy to look at while driving and i like the appearance
Attached Thumbnails where to mount gps-dscf0828.jpg   where to mount gps-dscf0822.jpg
fountainguy214 is offline
Old 08-03-2008 | 11:47 PM
Registered User
I made an aluminum bracket that is attached to the top right two screws on the instrument panel. I Milled it and bent it to the correct angle and then had it powder coated white to match the dash. Ran the wire down the right side of the panel and used adoll clamps in the existing holes that hold the instrument panel to the boat. I will uncover the boat later this week and post some pictures. It is not as complicated as it sounds and it looks factory with out making an new holes in the boat.
Dave Kahn
Dkahnjob is offline
Old 08-04-2008 | 07:48 AM
Beak Boater's Avatar
Charter Member # 545
From your avatar I assume you are running a 38 Fountain, I have an 07 38 also. I removed the compass Fountain mounts on top of the dash and mounted Garmin chart plotter their. I will show some pictures just have to find them.
Beak Boater is offline
Old 08-04-2008 | 07:49 AM
i appreciate it. With the race fairing its easier to mount something but i have the wind shield and dont wanna make it look like an eye soar. Not much room left w the smart craft in dash
Old 08-04-2008 | 10:23 AM
Here are the pictures of ours. I wanted it lower than the windsheild, but its almost impossible to find a gps that has a screen you can really see when you get real small. Thats why I went with a 172. Its just a little taller than the windsheild, but the wind is deflected over it. I can run down the river with the cover over it and it wont blow off the unit.
Attached Thumbnails where to mount gps-img_1398.jpg   where to mount gps-img_1399.jpg
Old 08-04-2008 | 10:54 AM
thanks for the pics
Tony Montana
6
07-08-2007 06:13 AM
JIMB
6
07-13-2005 06:46 PM
Stormrider
Active Thunder
2
10-21-2004 08:40 PM
kook
01-10-2002 01:35 PM
