-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Speed and Power of your 29 (https://www.offshoreonly.com/forums/fountain/194650-speed-power-your-29-a.html)
Racerngr1 09-04-2008 07:10 PM
What power do you have in your 27 and 29's? I would be interested in doing like a whipple on my boat; however, I want to see what hp it takes to get a similar boat to "x" speed. Right now the best I can get out of my 29 with a rebuilt 500 EFI is 72 on GPS (approx 470HP)
tbrown15239 09-04-2008 07:28 PM
29 fever I have twin 502"s just stock nothin fancy on average 75 mph with everything right I have seen 79 mph Im spinning 28 hydros that are labbed
Racerngr1 09-04-2008 07:56 PM
Exactly the kind of info I was hoping for. Thanks for the post
mcprodesign 09-04-2008 09:10 PM
You may need blower pistons. With My blower. I jump right on plane w a 28 pitch bravo.. I run mid seventies but need to tune some to get the right top end. Just been spending time in the boat with the lady and been on controlled speed lakes. Water skiin' and stuff. You can add 3 MPH for the 29 vrs. the 27.. And another 3 if you have the step bottom with the higher x dimention.
I may see 80 by the time i'm done. the best Ive seen is 77 gps w the wind and chop at my back on elsinore.I have a 27 with no step. But . I have a new tow vehicle.:D
badluck 09-04-2008 09:25 PM
27 Fever -93, carbed HP500, bravo 1 1,5 ratio, propshaft 4,5" below bottom, 14,5X24 Mach 4 blade.
71mph 5300rpm light load.
chewspit666 09-04-2008 09:30 PM
I have a 03 29 w/ 525 and a 27 hydro non labbed and I run 80 at 5400.
bleek 09-04-2008 11:18 PM
I have a 2000 29' with carbed 500hp running right at 73mph gps with a 24" pitch bravo one. I have a labbed hydromotive that gets me up around 75, but I lose my all around performance. I also have an XR drive with 1.5 gears,and dual water pick-up. I have been told the DWP might be a little slower but not much. I used to have a 1999 27' with a Tyler Crockett 502 putting out 575hp. That boat ran close to 80mph at 5200 rpms with a 27 pitch mach sterndriver, and 1.5 gears.
Racerngr1 09-04-2008 11:56 PM
You and I are pretty close as to how our 29's are running. I am having my 24P Hydromotive tuned right now so I can get some more RPM, then I think I will be close to 75ish.
Rebel_Heart 09-04-2008 11:57 PM
I used to have a 93 27'. Radared in the Shootout a couple of times at 80. I had a 572 NA bowtie Chevy block. Running a 28 labbed Hydromotive.
Griswald 09-05-2008 07:18 AM
'97 27 Fever - 509" w/ M1 Procharger and labbed 28 Bravo 1 - 77mph @ 5200. Been way hot down here this year and that's as tight as I can spin it. With some cooler weather and a bit more tuning I hope to touch 80
