Bilge Pump Recommendation >
Old 09-24-2008 | 11:44 AM
RUNNIN A FEVER's Avatar
Default Bilge Pump Recommendation
Caution Rant:
Damn attwood bildge pump under the motor has started running continously and tripping the breaker, which kills the stereo circuit. The damn thing is under the oil pan with only 1" clearance +/-, would have to be a yoga master to get to it. I got it out but it was not fun.
Rant Over.
Can anyone recommend a replacement for my out of date attwood guardian 1100 bilge pumps? Being that these are the main pumps for the boat I'd like to get ones that are easily serviced, and dependable.
Thanks for any help.
RUNNIN A FEVER is offline
Old 09-24-2008 | 05:32 PM
Originally Posted by RUNNIN A FEVER
Caution Rant:
Rant Over.
I would just replace both with Lovett pumps that come standard from Foumtain. Never seem to hear of too many problems with them.
RaggedEdge is offline
Old 09-24-2008 | 06:28 PM
Thanks, I'll check into them.
Old 09-24-2008 | 06:37 PM
Caution Rant:
Rant Over.
It must be that time of year, mines doing somthing similar runs all the time but not at full power, just a continuous hum. To prevent blowing fuses I just remove mine and put it in when I need it, no I don't leave it in a slip - trailered. If you get a chance send that yoga master my way cause mines located in about the same place. Biggest problem is unless I remove the battery and stow box I don't think you can even reach it much less try to disconect anything. OK Ragged you can give me crap now if you like.
Hot Stepper is offline
35 White Lightning
Fountain
2
08-24-2008 01:44 PM
Cruz-N-Thunder
5
07-13-2006 12:09 PM
