x-dim on '04-'05 35' lightning >
Old 11-13-2008 | 09:49 AM
Originally Posted by gnorthga
What Size Motors Are In That Boat You Are Going To Work On This Winter
It has 500 efi's w/ vortech SC and a little bigger cams. We tuned in the water so no dyno time to get actual numbers but I would guess something north of 700 ponies. Vortech claims:
700 HP @ 5400 RPM on 91 octane pump gasoline
716 lb./ft. @ 4400 RPM on 91 octane pump gasoline
but with the cam change I would guess another 30-50 hp per side.
I've had the boat to 99 and hit the limiters at 5650. I'm spinning 31" maximus props but I think I could use a little more pitch but she chine walks and hops pretty bad unless you are in rough enough water. The smoother the water the worse unruly it gets. I've been 95 with the tabs down to about 3.25-3.5 to keep her settled and the props blow out. The stock bravo lower is just punching a hole in the water big enough to lose bite. If I don't end up with a little bigger boat this winter I'm gonna put imco's and XR uppers on her this winter but I'd really like to find a 38 or 42 staggered and do a motor swap so we'll see what happens.
What power and what model are you running?
gofastlvr is offline
Old 11-13-2008 | 09:51 AM
here is a pic of the install
Old 11-13-2008 | 10:23 AM
Xr With Sport Master 1'' Spacer 32 6 Blades Run Rite At 100
gnorthga is offline
BeakBoater35
Fountain
24
04-08-2007 01:07 PM
Rebel_Heart
Fountain
15
04-01-2007 05:53 PM
PCI
Fountain
4
09-07-2006 02:03 PM
Rcolter
Fountain
5
05-16-2006 07:27 PM
jeff bratton
Fountain
2
12-05-2003 08:13 AM
