anchor pole light >
anchor pole light
anchor pole light
Old 01-05-2009 | 12:15 PM
Default anchor pole light
I have a 2000 27 fever that didn't come with a pole light for the back of the boat. I went and bought one and it didn't work. There are 3 pins in the boat and only 2 working connections on the pole. I checked to see how it was wired in the boat and it has the hot wire split going the the 2 pins and a ground wire to the other. Do I need a 3 pin light? I have voltage from the 2 pins to ground.
Rob
rmcdade is offline
Old 01-05-2009 | 06:06 PM
call fountain factory, they will send you a new one that works. 800-438-2055
topendmarine is offline
Old 01-06-2009 | 08:03 AM
thanks. I just called them and they said they are the only company that uses that type. It was $50
Rob
rmcdade is offline
enticer
06-12-2022 10:33 AM
razor1115
Fountain
21
08-31-2015 07:02 AM
h2oboy
08-28-2007 11:39 AM
Wild
07-24-2007 07:29 PM
SeaDated
05-04-2004 12:47 PM
