-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Advice on a 42' (https://www.offshoreonly.com/forums/fountain/202347-advice-42-a.html)
TeamShogren.com 02-01-2009 07:17 PM
Clarify HP & Drives
They're 650HP, sold this way from factory for many years. Drives are IMCO, not bravo one.
Originally Posted by JayFan (Post 2788505)
Thinking about buying this boat...any thoughts (good or bad!).
http://www.teamshogren.com/pre-owned...lightning.html
:ernaehrung004:
TeamShogren.com 02-01-2009 07:20 PM
FAster with two than 3 but lost some acceleration and picked up better ride.
The boat ran 99MPH with triple Joe Griffin 650's. We took one motor out, re-rigged as stagger, changed drive ratio and props, now it runs 102MPH.
www.teamshogren.com
Fountain & Baja By Fountain
847-336-9037
johnnyboatman 02-01-2009 07:49 PM
what prop and ratio
Lucky Strike Jr 02-02-2009 07:52 PM
Originally Posted by 35 fountain (Post 2790287)
yea but it aint gonna go anywhere near 90 with 500s
True (and I never said it would). But they are stock motors, which make a boat sell easier.
45sonic 02-02-2009 08:06 PM
www.teamshogren.com
847-336-9037
I thought that boat looked familiar
carcrash 02-03-2009 04:23 PM
Some things look really nice about that boat:
Because it was a triple, it has a somewhat filled in notch, meaning a bit more buoyancy aft, so less "beaver tail slap."
That all new dash, with a 'glass instead of aluminum panel, is worth a LOT of money. Nice not to have to deal with the corrosion around the switches, screws, instruments, ...
Probably good stuff:
New transom and stringers in the eingine compartment are probably a big advantage, if done properly. Looks well done.
Bad stuff:
Looks like it will have a LOT of trailer tongue weight, as the axles seem set aft for the weight of the third engine.
Its a vacuflsh head, but where is the vacuum pump? Not aft-starboard like usual.
