water pressure pick up >
Old 05-06-2009 | 09:00 AM
Default water pressure pick up
Hey guys I have got a 1997 29 fever with twins and one of the water pressure guages is not giveing me a reading but it does not overheat and was just wondering where it gets the pressure from ? The boat has bravo drives and 454 mags . Thanks for your help in advance .
chkmt251 is offline
Old 05-06-2009 | 09:23 AM
c_deezy's Avatar
Usually they get plumbed to one of the block drains on the lower part of the engine block. The other place that sometimes gets plumbed is the top of the intake manifold, around the thermostat area.
c_deezy is offline
Old 05-06-2009 | 10:48 AM
I think the thermostat is your better choice ,,because u need to know if water press is in the top end as well !!
DareDevil is offline
Old 05-06-2009 | 10:23 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
How do you have different WP between the block vs the intake???
Fountain uses 1 of the lower block drains for the WP gauges.
US1 Fountain is offline
Old 05-07-2009 | 07:06 AM
Kelly O's Avatar
Glenn,
Typically it is a small rubber line attached to a fitting threaded into the block drain as stated above. Should be disconnected to drain for winterizing, depending on how you winterize. I disconnect at both ends and blow back through to drain and clean. Probably some sediment or rust plugging it off, check at block end fitting.
Hope to see you on the water !
Kelly
Kelly O is offline
Old 05-09-2009 | 08:17 AM
Thanks guys ill check it out on sunday. Have you been on the lake yet Kelly?
chkmt251 is offline
Old 05-09-2009 | 05:56 PM
Kelly O's Avatar
Not yet, getting everything back together now, hope to fire it tomorrow. Cayuga will have some new players....... bigger, badder, and faster !!!!
Kelly O is offline
Old 05-09-2009 | 07:55 PM
32storm's Avatar
You may want to disconnect at both ends, than blow line out with compressed air. Also may want to remove block fitting & blow that out & check for junk/scale.
32storm is offline
Old 05-09-2009 | 11:44 PM
Sorry,,,what i mend is if you would have something wrong with the top end u would see it faster if thats where u take the WP !!!
Water feeds from block to topend so the last is where i like to read it !!
Maybe just me,,but it works!
Old 05-11-2009 | 10:11 AM
Great now you are going to make me spend more money . LOL See you on the water Im thinking a couple of super chargers mite wake it up
chkmt251 is offline
