Real Puzzling water problem
Registered User
David
Engine shot. Water everywhere. Typhoon recommends sending to Ron Potter and complete documentation and re-build (documentation because the shop that did the last re-build not 2 weeks ago may have installed the wrong CAM to create this problem. The only draw back with Potter is the travel time of the engine to Florida...Thoughts?
Gotta decide by Tuesday...
Dan
Dan
Registered User
Dan
Dan
Good luck with the project.
Dave
Typhoon Marine tore the engine down and it is shot!
I am considering a drop in rebuild by Joey Griffin sold thru Shogren...Any thoughts on this option?
I want to get going ASAP and would probably re-build the other as a back up.
Dan
Dan
Registered User
The best advice that I can think of is to go to a reliable shop that you trust and have them do the entire job, and have them supply all parts and etc. Be sure they pressure test the headers and all other accessories. Be sure that they are willing to take responsibility for the entire project from start to finish. That way if there is a problem you only have one person to go to and there won't be any finger pointing. Be sure they offer a complete package and warranty.
David
PS. The old engine rebuilt as a spare is a really good idea, since both engines in the boat have been to the same party and have the same amount of time on them.
You made need it sooner than you thought you would.
DK
teh oil was Milky and I ended up buying a new re-manufactured engine from Mercury and installed by Typhoon Marine. installed the High Rise HP risers...Typhoon did great work for me and I am dedicated to them from now on...
Dan
Dan
Conclusion, purchased a Re-manufactured HP500 from Merc, Typhoon installed it as well as new HPRiser pipes. This solved it all...$$$$ Only took time, money and the right guys to take care of it.
