More hydraulic seat issues.... >
Old 04-14-2010 | 12:45 PM
Default More hydraulic seat issues....
What would cause both of them to stop working? They are both ran off seperate pumps... Is it coincidence both switchs are bad? drivers seat has had issues not working, never any out of passenger seat, was working on drivers seat & passengers quit working.... What gives?
jmoore1225 is offline
Old 04-14-2010 | 01:03 PM
Did you check all the fuses? Under the rear seat.
Fountain Family is offline
Old 04-14-2010 | 07:45 PM
Yep....
Old 04-14-2010 | 08:16 PM
check for corrosion at all terminal conectors . also check grounds.
tim brown is offline
Old 04-14-2010 | 10:37 PM
Tim that's what I was doing to the drivers seats switch, started workin then both quit.... Tore apart passengers seat switch sanded all connections down & nothin.... Going to take a test light to it in the morning
Old 04-18-2010 | 07:41 PM
just keep looking , it can't me much .
Old 04-19-2010 | 11:13 AM
Alright fella's neither seat is getting power.... Ran a hot wire from the battery to the switchs, worked with no problems, up & down both seats.... All other switchs in boat works tabs, drives, lights everything but these damn seats.... Is there a hidden fuse for these things somewhere?
Old 04-19-2010 | 01:03 PM
A FUSE... A DAMN FUSE.... 1 of the glass fuses under the dash... I swear I've looked @ them 3 or 4 times.... Talk about feeling like a jack*ss....
Old 04-20-2010 | 09:29 AM
Active Streak: 30 Days
Don't just look at the fuses, test them. Somtimes they just come unsoldered at you cannot tell by looking at them.
Helmwurst is offline
