aft lift prop? >
aft lift prop?
aft lift prop?
Old 08-24-2010 | 10:07 AM
Default aft lift prop?
does a 93 27 ft fountain like a prop that has alot of aft lift to it , was wondering cause i am swithcing to a left hand 4 blade 22 pitch and some props i am looking at say they have alot of aft lift ? any ideas or help would be great .
money455 is offline
Old 08-28-2010 | 10:58 AM
I would say "Try it , don't buy it" If you have to buy one.. The Bravo 1 is the ticket. I got a '92 and I run a 28 RH. I have the Standard 1:5 lower unit. I got a blower so i can pull a big wheel. You should try a RH Bravo 1, what ever pitch you can pull to 5200 . B BLades will let you rent a prop to try for 25 bucks a week.
mcprodesign is offline
Old 08-28-2010 | 01:51 PM
General rule of thumb Ive heard is a conventional bottom likes a bow lifting prop (like the Mirage Plus or the Bravo 1) and a stepped bottom likes a stern or aft lifting prop (like the Hydromotive Quad IV). Your 93 Fountain would have a conventional bottom so I would think a Bravo 1 would be a good prop if you want 4 blades.
Powerquest_Baby!! is offline
Old 08-30-2010 | 09:23 AM
We have pretty much the same setup...so I'll share my experiences to date and maybe save you some time on yours. When I got my 94' 27fever it had a 23p RH Mirage Plus prop. The boat listed to starboard under power so I had to drag my starboard tab about 1 number to compensate for the starboard list. I changed my prop to a 22p LH Hydro Q4...that eliminated the starboard list and it does come out of the hole easier and runs faster in mid-range rpm...and it feels better at WOT. I don't know about the bow/aft lift thing, but I'm now thinking I will try a Bravo I 24p LH prop next. I'm thinking 24p because I've heard the Bravo I's are actually 2 pitch shy of the stated pitch number on the prop. Just my 2 cents worth...Good Luck!
Thunderstruck27 is offline
Old 08-30-2010 | 09:52 AM
Weird, if a boat with a single RH prop lists to stbd, it should only get worse with a LH prop...
Are you sure there isn't a typo somewhere?
mapism is offline
Old 08-30-2010 | 02:28 PM
No typos here...I may just have a special fever! lol
Old 09-01-2010 | 12:29 PM
mapism...do you have an older fever without a stepped hull?
Money455 & mcprodesign...have either of you noticed a starboard list using RH props?
Just wondering if I'm the only one who has experienced this.
Old 09-01-2010 | 01:08 PM
yes i do have the strbd list with my boat it is more minor than major but its there for sure . not to be long winded but i have tried a few diffrent 3 blade props and currently have a b1 24 pitch that was labbed down to a 23 and i guess its just too much pitch / prop cause i lost alot of rpm i am at 4400 rpm fully trimmed to #4 on the indicator and lost speed . i do have nice livorsi gauges and with a mirage plus 23 pitch i was right at 5k or a little over but could only get 60 mph ? there is no hiding it i have a slow boat lol ! but i love it . does anybody know of a really aggresive 3 blade prop for finding something over 60 mph !
money455 is offline
Old 09-01-2010 | 01:10 PM
also i am ready to sell my bravo 1 rt hand prop which is a 24 pitch labbed to 23 , i also have a mirage and mirage plus both 23 pitch un-labbed i gotta check to see what they are worth but i just want a fair price for them if anyone is interested .
money455 is offline
Old 09-02-2010 | 03:52 AM
Nope, it's actually one of the latest ever built, model year 07.
But the principle is pretty much valid for any V hull with a single screw: all other things being equal, a RH prop introduces a list to port, and a LH prop does the opposite.
It's also intuitive, if you think about it: the lower half of the prop is the one which "grabs" more water, and with a RH prop the lower half of the prop "pushes" the boat to rotate counterclockwise (looking at the boat from astern) around its longitudinal axis.
This applies also to boats with the outdrive installed deep in the water, but the effect is even more relevant when the outdrive is rather high, as it normally is on a 27 Fever.
On mine for instance the X dim is 19", which means that the prop shaft is only 2" 13/16 under the hull bottom, because on Bravos the distance between the engine shaft and the prop shaft is 21" 13/16.
mapism is offline
