Fountain Hatch Door >
Fountain Hatch Door
Fountain Hatch Door
Old 09-13-2010 | 09:41 PM
Default Fountain Hatch Door
The top hatch (right above the doors) in my 35' Fountain has a crack in it. I tried repairing it with epoxy, but that ended up looking pretty crappy and didn't work, so now I'm looking for a replacement. Does anyone out there have one off a boat that they'd be willing to sell? I know I'll probably have to go to Fountain directly to get a new one, but figured it couldn't hurt to ask. Thanks to anyone who might be able to help. PM me if you have anything-
Ben
northerndoc is offline
Old 09-14-2010 | 12:32 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
If your hatch is salvageable, use an Acrylic solvent glue. Might have better luck than plain 2 part epoxy. We use it at work and the acrylic will break before the joint. It's like water and wicks into the joint for a no glue look.
US1 Fountain is offline
Old 09-14-2010 | 07:32 AM
Sounds like it's worth a try- where do you get this stuff? Any brand names to mention? Thanks!
Old 09-14-2010 | 09:10 AM
Fountain4402's Avatar
if you still have all the hardware I would think an acryilic shop in town could replicate it
Fountain4402 is offline
Old 09-14-2010 | 10:44 AM
blownincome's Avatar
Or call Tony at Fountain 252-975-7006 Ben did you find your Oil leak??
blownincome is offline
Old 09-14-2010 | 12:19 PM
Ginger or Mary Ann?
We use Weld-On solvent. Should be able to buy it from your local plastic supplier. Might even just let them try to glue it. Might be cheaper than you buying a can of it,or as mentioned have them price one out for you. If bought from Fountain, I believe it will come with the hinge installed, at least mine was when I had replace one of my doors.
Old 09-14-2010 | 07:30 PM
bcfountain's Avatar
Registered User
Default cabindoors
my buddy had a 32fever andthe cabin door also broke.he was able to get the door from fountain but had to reuse the hinge assembly
bcfountain is offline
Old 09-14-2010 | 11:32 PM
I think anyone that's had a Fountain any length of time
has broken a door at least once.
Good info to have since I just broke one this past weekend.
4th Fountain in 15 years and 3rd broken door.
LuvMy47Ftn is offline
Old 09-15-2010 | 07:35 AM
I googled Weld-On that US1 talks about and found several dealers that sell it. Also found a site that explains how to use any of the several versions that Weld-On produces. It looked to me that Weld-on 40 would be the one for a novice to use, but it is a 2 part (solid and catalyst). Sounds like really good stuff thought. I'm going to try some on my doors where they're broken at the henges.
Thunderstruck27 is offline
Old 09-15-2010 | 01:45 PM
Active Streak: 30 Days
We use ehthylenedycloride....Will be strong as the plexi itself. Save up some money and buy one from Fountain next spring. I had to replace my left door and it fit without any issues.
Helmwurst is offline
