Originally Posted by fountainfan42
(Post 3506437)
correct:coolcowboy:
800-850hp range pump gas |
100mph You Better Put Larger Than Those I Got A 98 With 850s And 105 Is The Best Ive Seen 95 To A Hundred Any Day But Pushed It To Get 105, And I Bought Mine From The Same Guy. Its The Bottom That Make The Newer Ones With 850s So Much Faster.
but i will tell you that with 850s you will outrun several so called 120mph boats atleast we have. good luck with ur project i think u got a good deal on it mine was stripped worse than that.
Originally Posted by johnnyboatman
(Post 3507701)
what drives are you running? |
Originally Posted by n2ojoe
(Post 3506517)
Its a project for sure im going with whippled 540's want well over 100mph
800-850hp range pump gas Good Luck. |
| All times are GMT -5. The time now is 03:17 PM. |
