-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   raising the "X" (https://www.offshoreonly.com/forums/fountain/271696-raising-x.html)
35Fountain555 02-29-2012 09:11 PM
raising the "X"
Raising my engines in my non-stepped 35' Executioner. Higher 'X" should make propshaft centerline 2 3/4" below running surface. Engines dynoed at 675hp @ 5800 rpm. Going to run B-1's with cones & 1 1/4" shafts. Any input concerning this "X" ? Anybody tried this on non-stepped 35' ?
Reggie Fountain 02-29-2012 09:17 PM
Could definitely go up quite a bit. Give me a call tomorrow, my number is 252-495-4545.
excalibur82 03-01-2012 07:13 AM
I agree on that!!! I set mine at 21.25 and I think I could have went higher boat it picked up alot of speed..
Back4More 03-01-2012 01:48 PM
I wouldnt raise the engines, you want those as low in the boat as possible....just pop on some -2 lowers.
Thats what i did on a non step 42.
A.O. Razor 03-01-2012 02:12 PM
Wow, that's high with B1s. I bellive the new stagger 35 with its and -2 shorties run about 18½". ReggieIII can you confirm this? Just thinking.
1 MAIDEN AMERICA 03-01-2012 03:42 PM
X2
Or -4's now that they're available
35Fountain555 03-01-2012 08:20 PM
Thaks for interest & replies. Boat currently running about 15 1/4" on the "X" which puts running surface about 1" below the cavitation plate or prop shaft at 6 3/4" below running surface. I figured running the B-1's is asking fot trouble, but money is super tight. Hope was that running the B-1's would last long enough for me to afford 2" shorties putting at about 3/4".
racinfever 03-01-2012 10:04 PM
OLDER BOATS RAISING X
With no steps or small steps it seems like they run too flat & lose handling quality & lift. [ bravo style props] may be a rake issue. SSM props go as high as you can. Maybe Reggie could comment on our fears!
Would a high rake bravo style prop help? 4 or 5 blade?
47 lightning 03-02-2012 06:02 AM
What experience have you had with small stepped fountain boats? Because I currently own a 97 - 47 with twin small steps...I just raised X dimension to 24 inches or prop shaft height to 2 1/2 inches above the running surface. Any info would be appreciated..
excalibur82 03-02-2012 07:18 AM
My boat is an 84 it had #3 speed masters. I converted it to bravo's talked to alot of people even reggie on his cell and this is how I set it up. I have stock 420's with stainless marine exhaust and ran 78 on the gps... I didnt even play with props that was a stock pair of 26 bravo ones spinning them in at 5200.Gets on plane no problem with no tabs...I bet I could get 80 no problem....I know a guy with 420's and trs on his 85 10 meter and runs 70/72..The proof is in the pudding...
