some 32 questions >
some 32 questions
some 32 questions
Old 10-01-2012 | 05:09 PM
Originally Posted by US1 Fountain
I don't think the cooler will fully drain if you do so. Maybe just enough that a sponge or towel will pick up. To close to call. I thought of doing so too when I 1st bought my boat.
Thanks..
il have to look into it first..
boatnt is online now
Old 10-01-2012 | 07:34 PM
The other is for the bilge pump that is under the step.
Thanks for clearing that up US1,,,,,,,,,
My cooler used to be connected to the sink, it won't drian all the way and if you ever use the sink a little will go into the cooler.
I took mine out, not like it is a very good cooler anyway.
Wildman_grafix is offline
Old 10-01-2012 | 08:53 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Talking to yourself again I see.
Yep, that cooler location is a perfect spot for, oh, an AC unit!
US1 Fountain is offline
Old 10-02-2012 | 07:07 AM
so who has a picture of a sun pad with the Fountain logo and the 32 in the middle they can post???
Old 10-03-2012 | 02:50 AM
After having five fountains this cooler will leak into the step and get the carpet wet. I used to put a small valve at the end of the drain tube and aother pain draining after use. The cooler has no real insulation pretty much useless. If you leave anthing in there and forget about it and go out hit some big water you will crack the cooler. Last boat I cut it out and put this cooler in :
http://www.amazon.com/Engel-UC19-Qua...9+quart+cooler
Fits perfect and you can remove it. I built a base to give an inch or so.
Ken
klalonde is offline
Old 10-06-2012 | 08:40 AM
nobody?
Old 10-08-2012 | 07:01 PM
http://www.boattrader.com/listing/20...ever-101840296
Old 10-08-2012 | 08:17 PM
I just order this sunpad from Fountain today for my 32. $1012.18 two week turn around.
Lucky1456 is offline
Old 10-08-2012 | 08:26 PM
Did they say that the head rest would be included or not?
Old 10-15-2012 | 10:21 AM
so how do you guys winterize your 32s???
http://www.youtube.com/watch?v=vbyJ1eX0VQY
I was thinking of using this method,I was going to remove the water pump elbow hose and get a lot of the water out of the blocks,and letting it run for about 10 minutes on the ear muffs so the thermostats open up and let the antifreeze circulate and keep checking the strength of the antifreeze as it drains back in the bucket/pool ,any reason not too??
the drain plugs are a pain to get to as we all know..
