Engine room clean up >
Old 03-05-2013 | 07:21 PM
Default Engine room clean up
Decided to give my engine room a coat of paint while I am waiting on parts for my engines
jab052783 is offline
Old 03-05-2013 | 08:16 PM
Randy Nielsen's Avatar
Looking good
Randy Nielsen is offline
Old 03-05-2013 | 08:30 PM
Looks great what product did you use?
abones is offline
Old 03-05-2013 | 09:17 PM
Elbow grease just kidding I am using awl grip paint
Old 03-06-2013 | 05:10 AM
Looks great!
Fooddude is offline
Old 03-06-2013 | 11:05 AM
Looks good , maybe while the engines are out you should have the back rail re-powerdcoated. Just an idea
Finney is offline
Old 03-06-2013 | 01:28 PM
1 MAIDEN AMERICA's Avatar
Paint the other side red. I dare ya. Looks good, makes we want to do mine.
1 MAIDEN AMERICA is offline
Old 03-06-2013 | 02:01 PM
I am in the process of doing the same thing, hopefully finish up tonight. Using white rustoleom enamel with 8:1 hardener. Mine is slow going because I would not remove everything at once, one side at a time cause my memory sucks. Tonight will be the 4th in a row
4bus is offline
Old 03-06-2013 | 02:04 PM
I just noticed your tin foil trick.....this would have been a very useful tip to me 4 days ago looks great btw
4bus is offline
Old 03-06-2013 | 02:35 PM
Default tin foil
The tin foil trick works great even when you are spraying and not brushing
