A/C doesnt work..?
Does anyone have a solution for a broken A/C...? Not sure what is wrong with it yet.
What is it doing? - fan running inside - If yes then is the condenser making any noises, humming?
Is the breaker for the condenser on? If the condenser is humming for a few seconds RIGHT after it is turned on then turn the power off to the condenser and take the electrical cover off and look at the silver can. Is the top bulged up or dished down in? If it is bulged up then the capacitor is bad. Replace it with one that has the same readings. |
If you could possibly be more general that would be great lol
You want me to get technical - I can. I do this for a living. :lolhit:
I was referring to 5PTO, I mean usually you`d want to supply a little info on a problem.
Originally Posted by ICDEDPPL
(Post 3914735)
...... I mean usually you`d want to supply a little info on a problem.
A/C on a offshore?? Talk about something I would NEVER use (if I had it).
WHAT!? OMG I don`t know what Id do without AC on the boat.. oh wait I know, not sleep all night sticking to everything sweating my balls off. PASS!
Hey when your running along at 85-90+ MPH who needs AC?
I do not have the boat in my possession as of yet. I had a survey done and they said it did not work. It is a factory installed A/C on a 35' Fountain. Once I have more info I will post it here. Hopefully its nothing to serious.
| All times are GMT -5. The time now is 04:25 AM. |
