Question for 38 and 42 owners >
Old 12-14-2013 | 02:06 PM
  #31
Go for the 42' the from 2004 to current all 42 have the same bottoms. all the 700 boats have #6 drives no nxt
27Fountain is offline
Old 12-14-2013 | 03:53 PM
  #32
I always thought they ran the NXT trans, upper, and transom assembly with a 6 lower?
Jpzaluski is offline
Old 12-17-2013 | 03:44 PM
  #33
On Time's Avatar
Have you had any drive issues? If the setup is reliable that isn't bad. Pretty much the same speed I get out of a 32, with HP500EFI motors.
Yes developed a slight gear whine on port at about 200 hrs. This is after religious annual care and moderate running with minimal air time. I don't go for big air because I know the damage it can do. On my outboard boat I needed lowers after too much "big air". So, got new lowers built and the next 130 hrs. no gear isssues but did have to replace both upper pivot bearings at about 300 hrs.
On Time is offline
Old 12-18-2013 | 05:30 PM
  #34
No, Fountain used the NXT transom assembly, the NXT transmission, and the entire No 6 drive unit. This was the standard for all the 700 / 6 boats. Reason was that the NXT drive did not work worth a chit on the Fountain hull.
RaggedEdge is offline
Old 12-24-2013 | 09:38 AM
  #35
Ran-Dom 32's Avatar
Originally Posted by obnoxus
What was done to get a stock 525 boat to 90 mph ??
http://www.offshoreonly.com/classifi...o55027-en.html
is this the boat in question? either way this 525 boat is dialed in
Ran-Dom 32 is offline
Old 12-24-2013 | 12:28 PM
  #36
obnoxus's Avatar
Charter Member #1171
With sportmaster shorties,,,,,, Id like to be there to watch him get that thing on plane
It is hard enough with stock Bravos and 5 blades
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 12-28-2013 | 01:16 PM
  #37
Yeap . Damn nice boat. But it will throw blades off those herings getting on plane most likley
mcprodesign is offline
Old 12-28-2013 | 03:52 PM
  #38
My new to me 47 has the same lowers and 6 blade herings... but I have three of them... do you guys think I will have similar problems as you're suggesting here? previous owner didn't seem to have that problem...
HyFive578 is offline
Old 12-29-2013 | 12:42 AM
  #39
I think the all white poker run 42 at loto had problems throwing shoes as well. Pretty sure it
ran shorties also.
dlange is offline
Old 12-31-2013 | 08:37 AM
  #40
obnoxus's Avatar
I would not think so because the transom sits deeper,,,,,,how is it getting on plane?
Do the props blow out easily?
obnoxus is offline
