Erratic Depth Gauge PROBLEM FOUND! >
Old 08-16-2002 | 09:46 PM
rjcardinal's Avatar
Default Erratic Depth Gauge PROBLEM FOUND!
While installing a marine radio in the boat today I pulled off an interior panel to run some wire and noticed a screw that holds the panel on was screwed into the coax cable that goes to the transducer. I mean you couldnt have drilled through the center of the cable more perfectly if you tried. This would explain why sometimes the gauge doesnt work. At first I thought this punctured wire was just a wire to the small bilge pump in the front. When I went to splice the wire to eliminate the chewed up portion I noticed it was a small coax cable. I traced it and it went to the transducer.
Now, does anyone if you can splice this small coax cable? It looks to be between 1/8" and 3/16" in diameter. If I cant splice the cable I will have to replace the transducer. The cable looks to be potted in the transducer with epoxy.
Ron
rjcardinal is offline
Old 08-16-2002 | 10:21 PM
envision
I beleive my old Lorance said you can splice the coax cable if you use a foil or other shielding material in the splice.
But my question is; does you depth gage work under 5 feet? Mine does not work. The Gaffrig instruction manual for the Teleflex gage says to call Hummingbird for info.
They don't understand why it works good above 5 feet but not at all below 5.0.
Good Luck!
Old 08-18-2002 | 09:43 PM
Mate 229's Avatar
RJ
You can splice coax cable. Go to an electronics store like Radio Shack or even Home Depot, they will have what you need. I would tape the splice with some good tape or a gel filled cover to keep moisture out. If you use vinyl tape remember to stretch it about 1/3 more than it's static length to get a good seal, most people don't do that and get a bad seal.
Mate 229 is offline
Old 08-19-2002 | 10:10 AM
rjcardinal's Avatar
Thanks Mate,
I have spliced coax before but never any as small as this. The diameter of the cable is less than 3/16". I will go to Radio Shack today and ask them. The last few times I went to the Shack the people there were friendly but totaly useless. These people should be working at convience stores. Maybe I should try some industrial electric supplier.
There is probably a tool to do it with that cost about $80 with my luck.
Ron
STUCK
Baja
7
04-13-2008 08:39 PM
FormulaM2Formula
02-18-2007 08:33 PM
US1 Fountain
Fountain
17
07-23-2005 11:25 PM
blownboat
3
05-31-2004 10:50 AM
fountain27ho496
Fountain
7
07-25-2002 12:50 PM
