Water Pressure Gauge >
Old 07-21-2014 | 06:36 PM
SB
Is 'thermal state' Floridian lingo for 'Thermostat?'
SB is offline
Old 10-27-2014 | 07:07 AM
Originally Posted by Kelly O
Pretty sure that's a mechanical gauge, does it have a rubber line running to it ?
Probably froze due to not being drained when winterizing. If it sweeps the same as the other gauge, your pressures are probably the same for each motor. Replacing the gauge would fix it.
So where does it attach to the engine? Have never done these but figured I should this year.
RaggedEdge is offline
Old 10-27-2014 | 11:11 AM
Port side block drain is where mine is connected. Beside draining the gauge of water, it's also nice to blow out all the sediment that gets in the hose.
Cole2534 is offline
Old 10-27-2014 | 11:56 AM
Thanks but have 525 EFI's, closed cooling here.
Anyone have the answer?
